[postgis-users] Bounding Circle instead of Bounding Box
Shane Spencer
shane at bogomip.com
Mon Sep 10 08:46:53 PDT 2007
Could you reply with a URL to what buffers are and how they would be used in
this context? I'm totally unfamiliar.
On 9/9/07, Nico Mandery <nicomandery at googlemail.com> wrote:
> Hi Rainer,
> You could could use a buffer instead of bounding boxes.
> Just an idea
> Nico
> Am Sonntag 09 September 2007 schrieb postgis at jochem.name:
> > Hi,
> > what I want to do is finding certain features in some distance around a
> > certain point. Those features should be located in some corridor between
> X
> > and Y km around this point. Currently I've solved this problem by
> > computing two bounding boxes of X and Y km around the point and taking
> the
> > difference of those. So far so good.
> > But I don't want to have some quadratic box but a real circle - is there
> > any way to achieve this?
> > Best regards,
> > Rainer
> > postgis-users mailing list
> > postgis-users at postgis.refractions.net
> > http://postgis.refractions.net/mailman/listinfo/postgis-users
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20070910/1bda96c0/attachment.html>
