[postgis-users] ST_<function> vs <function>
Stephen Woodbridge
woodbri at swoodbridge.com
Mon Sep 10 17:42:10 PDT 2007
This is all I could find:
Added versions of functions with standard ST (Spatial Type) prefixes to
any functions that were lacking them. Updated the regression tests to
include the new functions.
Richard Greenwood wrote:
> I'm embarrassed to ask, but what does "ST" stand for?
> Rich
> On 9/10/07, Obe, Regina <robe.dnd at cityofboston.gov> wrote:
>> Steve,
>> Just to add to what Mark said. There is a little bit more going on than
>> simply a renaming.
>> Most if not all of the ST relation functions have automatic index use
>> enabled in them.
>> For example
>> the old within is really closer to the hidden _ST_Within and the new
>> ST_Within function is equivalent to writing the old
>> geom1 && geom2 AND Within(geom1, geom2)
>> Same goes for ST_Contains, ST_Overlap etc.
>> Hope that helps,
>> Regina
>> ________________________________
>> From: postgis-users-bounces at postgis.refractions.net on
>> behalf of Mark Cave-Ayland
>> Sent: Sun 9/9/2007 4:30 PM
>> To: PostGIS Users Discussion
>> Subject: Re: [postgis-users] ST_<function> vs <function>
>> On Sun, 2007-09-09 at 16:03 -0400, Stephen Woodbridge wrote:
>>> Hi all,
>>> I seem to have missed reading some vital post or something.
>>> What is the difference between ST_<function>() and <function>()?
>>> Is this just a renaming for namespace issues?
>>> Are the <function>() names deprecated?
>>> Are there other benefits to this renaming?
>>> Please explain or point me to the relevant docs.
>>> Thanks,
>>> -Steve
>> Hi Stephen,
>> I don't remember there being much discussion about this, but the
>> relevant commit can be found here:
>> http://postgis.refractions.net/pipermail/postgis-commits/2007-June/000074.html.
>> In short, the old function names are deprecated, and new applications should
>> start to use the ST_ prefix functions instead.
>> ATB,
>> Mark.
>> ILande - Open Source Consultancy
>> http://www.ilande.co.uk
>> postgis-users mailing list
>> postgis-users at postgis.refractions.net
>> http://postgis.refractions.net/mailman/listinfo/postgis-users
>> The substance of this message, including any attachments, may be
>> confidential, legally privileged and/or exempt from disclosure pursuant to
>> Massachusetts law. It is intended solely for the addressee. If you received
>> this in error, please contact the sender and delete the material from any
>> computer.
