[postgis-users] Intersection errors out with null directed edge
Martin Davis mbdavis at refractions.net
Thu Sep 13 08:28:37 PDT 2007
Chris,
As Andreas pointed out, recent (Dec 06) work on GEOS has largely fixed
this problem (which is likely due to a robustness issue - although it
could also be due to invalid data!  You should check your data to make
sure it is fully valid, using isValid() )
Try upgrading and see if the problem goes away.  There's not really any
other great solution to this problem.
Martin
Chris Hermansen wrote:
> Hi folks;
> I had this problem today:
> AssertionFailedException: EdgeRing::computePoints: found null Directed
> Edge
> I see in the archives that there are others who have suffered this, back
> in 2006 and then in 2005, but there don't seem to be any offerings of
> techniques to either repair the code or the data - and based on the
> error above, I'm not sure which is ultimately at fault.
> Does anyone have some more up-to-date thought on this?
> I'm running postgis-1.3.1 on Ubuntu with the packaged postgresql-8.2
> installed.
> Thanks in advance!
Martin Davis
Senior Technical Architect
Refractions Research, Inc.
(250) 383-3022
