[postgis-users] Converting GMaps.getBounds to POLYGON ewkt format
Robert Coup
robert.coup at onetrackmind.co.nz
Fri Sep 14 21:21:23 PDT 2007
On 15/09/2007, Babu Naidu <pbnaidu at gmail.com> wrote:
> I am trying to convert Google Maps GMap.getBounds() (which returns LatLng
> for south west and LatLng for north east)
> to POLYGON( ) ewkt format. This is to query for points within that POLYGON.
> I think I figured out the format and I would like to verify it with experts
> here. I have southwest Lat Lng and northeast LatLng
> considering Y=Lng and X=Lat
> POLYGON(maxY maxX,
> maxY minX,
> minY minX,
> minY maxX,
> maxY maxX)
> Is this the right way to create a POLYGON? could you please point me to docs
> if available that explain this format?
X should be Longitude, and Y Latitude. Always.
in WKT you need double-brackets for a polygon, and the common
convention is to do boxes in the following sequence:
POLYGON((minx miny, maxx miny, maxx maxy, minx maxy, minx miny))
If you don't need to make WKT you could do the following instead,
which creates a geometry you can use in queries, etc:
MakeBox2D(MakePoint(minx, miny), MakePoint(maxx, maxy))
hth,
Rob :)
