[postgis-users] unable to assign hole to a shell
Patrick Valsecchi patrick.valsecchi at camptocamp.com
Sat Sep 15 15:53:22 PDT 2007
I was trying to play with polygons on PostGIS and I found this one to be quite
troublesome:
POLYGON((9.50351715087891 47.3943328857422,9.50386047363281
47.3943328857422,9.50351715087891 47.3943328857422,9.50248718261719
47.3943328857422,9.50214385986328 47.3939895629883,9.50180053710938
47.3943328857422,9.50145721435547 47.3939895629883,9.50111389160156
47.3936462402344,9.50145721435547 47.3936462402344,9.50145721435547
47.3939895629883,9.50214385986328 47.3939895629883,9.50248718261719
47.3939895629883,9.50386047363281 47.3943328857422,9.50351715087891
47.3943328857422))
When given to st_buffer(), it will throw this error:
NOTICE:  AssertionFailedException: unable to assign hole to a shell
ERROR:  GEOS buffer() threw an error!
I don't understand... if you look at it, it looks like an armless polygon.
More details (picture) can be found here:
http://patrick.blog.thus.ch/?p=8
I'am using PostgresQL 8.2.4 on a Debian install with:
POSTGIS="1.3.1" GEOS="2.2.3-CAPI-1.1.1" PROJ="Rel. 4.5.0, 22 Oct 2006"
USE_STATS
Does anybody have an idea on what my problem is?
Thanks
