[postgis-users] AsKML() how to create kml from postgis data
Milo van der Linden mlinden at zeelandnet.nl
Sun Sep 16 08:17:18 PDT 2007
Hold it, stop, take a look at this first!
This post was sent on the mapserver list last friday, please check if
this will your demands!
http://www.itopen.it/soluzioni/kml-map-server/
Dylan Beaudette schreef:
> On Friday 14 September 2007, John Smith wrote:
>> as_kml()?! there's another askml() in line with asgml(). why this
>> alias/name change/confusion?
>> anyway how does it really work? getting a "Must contain
>> 'geometry_column from table_name' or 'geom from (subselect) as foo'
>> (couldnt find ' from ')". what do i do after passing bbox=... and
>> type=kml to export script? the sql doesn't go inside .map, right? can
>> some share a detailed use/script? not much in
>> http://postgis.refractions.net/docs/postgis.pdf
> I'll add a bit to this discussion, as I have tackled it before.
>> btw super example at
>> http://casoilresource.lawr.ucdavis.edu/ka-map/htdocs/?map=casoil&cps=-20125
>> 07.9410234897,-132997.150403761,500000&layers=__base__
> Thanks! Here is a shorter link to the corresponding page:
> http://casoilresource.lawr.ucdavis.edu/drupal/node/429
>> although i didn't
>> quite get this part:
>> 1. select geometry overlapping the bounding box defined by the current
>> viewport in AEA coordinates, using the PostGIS spatial indexing system
>> 2. compute the intersection between the boinding box and the
>> overlapping polygons
>> 3. compute the centroids of the new geometry
>> 4. convert the polygon geometry to KML
>> 5. convert the centroid geometry to KML
>> 6. return resulting text
> This is a list of how the PHP code is functioning; some background--
> I have a massive table of polygons, stored in a custom AEA projection. Google
> Earth is not happy about massive KML files, so PostGIS is used to 'cut-out'
> (intersection) a chunk. This chunk is then converted into KML, with all of
> the extra XML styling etc. added by a PHP wrapper script. A second pass is
> done with PostGIS to get the centroids of the polygons, which are used as a
> labeling mechanism. All of the KML / XML chunks are stuck into a dynamically
> generated KML document and returned to the user.
> I was able to construct this by
> 1. looking over the KML specs
> 2. looking at some example KML files
> 3. experimentation
> Further work should definitely use something other than string functions to
> build the XML.
> Another hint: be sure to send the KML header by PHP first:
> 		header("Pragma: public"); // required
> 		header("Expires: 0");
> 		header("Cache-Control: must-revalidate, post-check=0, pre-check=0");
> 		header("Content-Type: application/kml; charset=utf8");
> 		header('Content-Disposition: attachment; filename="file.kml"') ;
> check out the examples on the above link, and dissect the resulting KML file
> for hints.
> Cheers,
> Dylan
>> cheers, jzs
>> On 9/14/07, Jose Gomez-Dans <jgomezdans at gmail.com> wrote:
>>> Hi Maciej,
>>> I sent you an e-mail, but your spam protection system wouldn't allow
>>> the message to go through.  If you have another address, I'll resend
>>> it to you :)
>>> On 9/14/07, Maciej Skorczewski <maciej.skorczewski at procad.pl> wrote:
>>>> how sql should looks like?
>>> Simply (and this is already quite advanced: you can use simplify() to
>>> reduce the number of points in your vector data. Ours are very
>>> detailed, and we don't want that on our KML files):
>>> SELECT AS_KML(SIMPLIFY(the_geom,100)) from MY_TABLE;
>>>> Question about Python class...i am not python programer can you
>>>> describe my how i can use it?
>>> You just write a small python program to use it. You should be able to
>>> do the same with PHP.
>>> Cheers,
>>> José
>> postgis-users mailing list
>> postgis-users at postgis.refractions.net
>> http://postgis.refractions.net/mailman/listinfo/postgis-users
Milo van der Linden
skype: milovanderlinden <skype:milovanderlinden?add>
mlinden at zeelandnet.nl <mailto:mlinden at zeelandnet.nl>
milovanderlinden at gmail.com <mailto:milovanderlinden at gmail.com>
milo at 3dsite.nl <mailto:milo at 3dsite.nl>
http://www.3dsite.nl
De informatie in dit bericht reflecteert mijn persoonlijke mening en
niet die van een bedrijf of instantie. Aan de informatie kunnen geen
rechten worden ontleend. Indien dit bericht onderdeel is van een forum,
mailing-list of community dan gelden automatisch de bij het betreffende
medium behorende voorwaarden. The information in this message reflects
my personal opinion and not that of a company or public body. All rights
reserved.If this message is contained in a mailing-list or community,
the rights on the medium are automatically adapted.
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20070916/3dacbdb4/attachment.html>
