[postgis-users] AsKML() how to create kml from postgis data
Maciej Skorczewski
maciej.skorczewski at procad.pl
Sun Sep 16 23:53:49 PDT 2007
thx Kevin for replay!
great help.
maciek
Kevin Neufeld pisze:
> Absolutely.
> See attached, a simple plpgsql function that adds header info around the
> current askml function.
> I do this in psql:
> -- Set output to unaligned
> \a
> -- Show only tuples
> \t
> -- Dump query to a file
> \o my_kml_file.kml
> -- Run your query
> SELECT askml('my_line', 'description', 'SRID=3005;LINESTRING( 1190000
> 390000, 1200000 390000, 1200000 380000, 1190000 380000, 1190000 390000
> )'::geometry);
> -- Flush output your file and close the output stream
> \o
> Loading this file in Google Earth will draw a box around Victoria, BC.
> I often collect() geometries from a table and pass those into this
> function:
> SELECT askml('my_title', 'description', collect(the_geom)) FROM my_line
> table WHERE ....
> Cheers,
> Kevin
> Kevin Neufeld
> Software Developer
> Refractions Research Inc.
> 300-1207 Douglas St.
> Victoria, B.C., V8W 2E7
> Phone: (250) 383-3022
> Email: kneufeld at refractions.net
> Maciej Skorczewski wrote:
>> hi all!
>> How should i use AsKML() function to create KML files (w try show
>> postgis data in google maps nad google earth)
>> It is posible?
> postgis-users mailing list
