[postgis-users] UNION
RAVI KUMAR
ravivundavalli at yahoo.com
Mon Sep 17 06:03:44 PDT 2007
Hi Regina,
giving the link to show actual how the UNION of polygons is not working as per expectation.
Please see the clips in the link.
CREATE TABLE abc(code smallint, info smallint) with oids;
SELECT AddGeometryColumn('public', 'abc', 'the_geom', 4326, 'MULTIPOLYGON', 2);
--The insert
INSERT INTO abc(code, info, the_geom)
SELECT newtb.code, newtb.info, geomunion(newtb.cgeom) as thenewgeom
FROM
( SELECT a.code, b.info, geomunion(a.geometry, b.geometry) as cgeom
FROM a
INNER JOIN b ON a.geometry && b.geometry AND intersects(a.geometry, b.geometry)
UNION ALL
SELECT a.code, null As info, a.geometry as cgeom FROM a
LEFT JOIN b ON a.geometry && b.geometry AND intersects(a.geometry, b.geometry)
WHERE b.geometry IS NULL
UNION ALL
SELECT null as code, b.info, b.geometry as cgeom
FROM b LEFT JOIN a ON a.geometry && b.geometry AND intersects(a.geometry, b.geometry)
WHERE a.geometry IS NULL
) AS newtb
GROUP BY newtb.code, newtb.info
May be I should be using different syntax for such a result.
http://www.kodakgallery.com/I.jsp?c=cjns10h3.8ovw4dsn&x=0&y=w3kbw0
Ravi Kumar
Catch up on fall's hot new shows on Yahoo! TV. Watch previews, get listings, and more!
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20070917/11e32dcc/attachment.html>
