[postgis-users] UNION
RAVI KUMAR
ravivundavalli at yahoo.com
Tue Sep 18 02:38:35 PDT 2007
a and b, are multiple tables derived from -2- shape files saved as POST-GIS data.
Slide 1:
'a' this data as in the slide show has attributes, This is a square with polygons.
'b' as in the slide show is made up of 2 polygons with attributes which overlap 'a'.
Slide 2: a and b are in UNION with the syntax below. But this is not the desired result. There are polygons overlapping other polygons, one below the other.
Slide 3:
'abc' is a union of a and b, with desired result
My further analysis with post GIS awaits HELP.
Cheers
Ravi Kumar
"Obe, Regina" <robe.dnd at cityofboston.gov> wrote: Ravi,
Is the graphic one record or multiple records? If multiple records - I'm afraid you may be asking 2 conflicting questions depending on your dataset so I'm not sure there is anything that can remedy that aside from treating them as two separate questions.
I'm also afraid you are getting into territory I'm very weak. You may want to investigate use of st_boundary (which will give you a multilinestring of a polygon/multipolygon boundary and then apply buildarea to that).
The below should get rid of some redundant overlapping polygons, but probably won't completely satisfy what you want to do. I'm also thinking you may want to be using intersection instead of geomunion for the inner part. But again depends what you are trying to answer.
INSERT INTO abc(code, info, the_geom)
SELECT newtb.code, newtb.info, multi(buffer(geomunion(distinct newtb.cgeom), 0.0)) as thenewgeom
FROM
( SELECT a.code, b.info, intersection(a.geometry, b.geometry) as cgeom
FROM a
INNER JOIN b ON a.geometry && b.geometry AND intersects(a.geometry, b.geometry)
UNION ALL
SELECT a.code, null As info, a.geometry as cgeom FROM a
LEFT JOIN b ON a.geometry && b.geometry AND intersects(a.geometry, b.geometry)
WHERE b.geometry IS NULL
UNION ALL
SELECT null as code, b.info, b.geometry as cgeom
FROM b LEFT JOIN a ON a.geometry && b.geometry AND intersects(a.geometry, b.geometry)
WHERE a.geometry IS NULL
) AS newtb
GROUP BY newtb.code, newtb.info
Hope that helps,
Regina
From: postgis-users-bounces at postgis.refractions.net [mailto:postgis-users-bounces at postgis.refractions.net] On Behalf Of RAVI KUMAR
Sent: Monday, September 17, 2007 9:04 AM
To: postgis
Subject: [postgis-users] UNION
Hi Regina,
giving the link to show actual how the UNION of polygons is not working as per expectation.
Please see the clips in the link.
CREATE TABLE abc(code smallint, info smallint) with oids;
SELECT AddGeometryColumn('public', 'abc', 'the_geom', 4326, 'MULTIPOLYGON', 2);
--The insert
SELECT newtb.code, newtb.info, geomunion(newtb.cgeom) as thenewgeom
FROM
( SELECT a.code, b.info, geomunion(a.geometry, b.geometry) as cgeom
FROM a
UNION ALL
UNION ALL
) AS newtb
May be I should be using different syntax for such a result.
http://www.kodakgallery.com/I.jsp?c=cjns10h3.8ovw4dsn&x=0&y=w3kbw0
Ravi Kumar
Catch up on fall's hot new shows on Yahoo! TV. Watch previews, get listings, and more!
The substance of this message, including any attachments, may be confidential, legally privileged and/or exempt from disclosure pursuant to Massachusetts law. It is intended solely for the addressee. If you received this in error, please contact the sender and delete the material from any computer.
postgis-users mailing list
postgis-users at postgis.refractions.net
http://postgis.refractions.net/mailman/listinfo/postgis-users
Need a vacation? Get great deals to amazing places on Yahoo! Travel.
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20070918/fe11d49e/attachment.html>
