[postgis-users] UNION
Kevin Neufeld
kneufeld at refractions.net
Wed Sep 19 08:45:50 PDT 2007
Regina,
Looking at the code, it appears
- the aggregate ST_Polygonize() was added in version 1.2.2,
- the aggregate Polygonize() was deprecated in version 1.2.3
It also looks like this deprecation is nothing more than a change of the
prototype. The original code was introduced in 1.0.0.
Cheers,
Kevin
Kevin Neufeld
Software Developer
Refractions Research Inc.
300-1207 Douglas St.
Victoria, B.C., V8W 2E7
Phone: (250) 383-3022
Email: kneufeld at refractions.net
Obe, Regina wrote:
> Kevin,
> When was st_polygonize introduced? The docs say it was introduced in
> 1.0.0 RC1? I see it in my newere 1.3 databases. I don't see it in my
> 1.2.1 corrupted upgrade to 1.3. I suspect this is because of the long
> standing issue of the bug in upgrading aggregates with soft
> upgrade and I have had a db that has existed pre 1.0 and I forget the
> last time I did a complete upgrade on it.
> Thanks,
> Regina
> *From:* postgis-users-bounces at postgis.refractions.net
> [mailto:postgis-users-bounces at postgis.refractions.net] *On Behalf Of
> *Kevin Neufeld
> *Sent:* Tuesday, September 18, 2007 3:43 PM
> *To:* PostGIS Users Discussion
> *Subject:* Re: [postgis-users] UNION
> It sounds like you are after performing an overlay operation on two
> polygonal datasets.
> I would do something like:
> - extract all lines from your polygons
> - node the linework
> - re-polygonize the noded lines
> - transfer attributes from the original dataset to the newly formed
> polygons.
> http://postgis.refractions.net/support/wiki/index.php?ExamplesOverlayTables
> Hope this helps,
> Kevin
> Kevin Neufeld
> Software Developer
> RAVI KUMAR wrote:
>> Hi,
>> a and b, are multiple tables derived from -2- shape files saved as
>> POST-GIS data.
>> Slide 1:
>> 'a' this data as in the slide show has attributes, This is a square
>> with polygons.
>> 'b' as in the slide show is made up of 2 polygons with attributes
>> which overlap 'a'.
>> Slide 2: a and b are in UNION with the syntax below. But this is not
>> the desired result. There are polygons overlapping other polygons,
>> one below the other.
>> Slide 3:
>> 'abc' is a union of a and b, with desired result
>> My further analysis with post GIS awaits HELP.
>> Cheers
>> Ravi Kumar
>> */"Obe, Regina" <robe.dnd at cityofboston.gov>/* wrote:
>> Ravi,
>> Is the graphic one record or multiple records? If multiple
>> records - I'm afraid you may be asking 2 conflicting questions
>> depending on your dataset so I'm not sure there is anything that
>> can remedy that aside from treating them as two separate questions.
>> I'm also afraid you are getting into territory I'm very weak.
>> You may want to investigate use of st_boundary (which will give
>> you a multilinestring of a polygon/multipolygon boundary and
>> then apply buildarea to that).
>> The below should get rid of some redundant overlapping polygons,
>> but probably won't completely satisfy what you want to do. I'm
>> also thinking you may want to be using intersection instead of
>> geomunion for the inner part. But again depends what you are
>> trying to answer.
>> INSERT INTO abc(code, info, the_geom)
>> SELECT newtb.code, newtb.info
>> <http://newtb.info/>, multi(buffer(geomunion(distinct
>> newtb.cgeom), 0.0)) as thenewgeom
>> FROM
>> ( SELECT a.code, b.info
>> <http://b.info/>, *intersection*(a.geometry, b.geometry) as cgeom
>> FROM a
>> INNER JOIN b ON a.geometry && b.geometry AND
>> intersects(a.geometry, b.geometry)
>> UNION ALL
>> SELECT a.code, null As info, a.geometry as cgeom
>> FROM a
>> LEFT JOIN b ON a.geometry && b.geometry AND
>> WHERE b.geometry IS NULL
>> UNION ALL
>> SELECT null as code, b.info <http://b.info/>, b.geometry as cgeom
>> FROM b LEFT JOIN a ON a.geometry && b.geometry AND
>> WHERE a.geometry IS NULL
>> ) AS newtb
>> GROUP BY newtb.code, newtb.info <http://newtb.info/>
>> Hope that helps,
>> Regina
>> Of *RAVI KUMAR
>> *Sent:* Monday, September 17, 2007 9:04 AM
>> *To:* postgis
>> *Subject:* [postgis-users] UNION
>> Hi Regina,
>> giving the link to show actual how the UNION of polygons is not
>> working as per expectation.
>> Please see the clips in the link.
>> CREATE TABLE abc(code smallint, info smallint) with oids;
>> SELECT AddGeometryColumn('public', 'abc', 'the_geom', 4326,
>> 'MULTIPOLYGON', 2);
>> --The insert
>> SELECT newtb.code, newtb.info <http://newtb.info/>,
>> geomunion(newtb.cgeom) as thenewgeom
>> FROM
>> ( SELECT a.code, b.info <http://b.info/>,
>> geomunion(a.geometry, b.geometry) as cgeom
>> FROM a
>> UNION ALL
>> FROM a
>> UNION ALL
>> ) AS newtb
>> May be I should be using different syntax for such a result.
>> http://www.kodakgallery.com/I.jsp?c=cjns10h3.8ovw4dsn&x=0&y=w3kbw0
>> <http://www.kodakgallery.com/I.jsp?c=cjns10h3.8ovw4dsn&x=0&y=w3kbw0>
>> Ravi Kumar
>> Catch up on fall's hot new shows
>> <http://us.rd.yahoo.com/tv/mail/tagline/falltv/evt=47093/*http://tv.yahoo.com/collections/3658%20>
>> on Yahoo! TV. Watch previews, get listings, and more!
>> *The substance of this message, including any attachments, may be
>> confidential, legally privileged and/or exempt from disclosure
>> pursuant to Massachusetts law. It is intended solely for the
>> addressee. If you received this in error, please contact the
>> sender and delete the material from any computer. *
>> postgis-users mailing list
>> postgis-users at postgis.refractions.net
>> http://postgis.refractions.net/mailman/listinfo/postgis-users
>> Need a vacation? Get great deals to amazing places
>> <http://us.rd.yahoo.com/evt=48256/*http://travel.yahoo.com/;_ylc=X3oDMTFhN2hucjlpBF9TAzk3NDA3NTg5BHBvcwM1BHNlYwNncm91cHMEc2xrA2VtYWlsLW5jbQ-->on
>> Yahoo! Travel.
> addressee. If you received this in error, please contact the sender
