[postgis-users] How to get the centroid of an bounding box using st_extent
Paul Ramsey pramsey at refractions.net
Wed Sep 19 09:46:33 PDT 2007
In particular, these ones are used by the casts.
-- Availability: 1.2.2
CREATEFUNCTION ST_geometry(box2d)
         RETURNS geometry
         AS '@MODULE_FILENAME@','BOX2DFLOAT4_to_LWGEOM'
         LANGUAGE 'C' _IMMUTABLE_STRICT; -- WITH (isstrict,iscachable);
CREATEFUNCTION ST_geometry(box3d)
         RETURNS geometry
         AS '@MODULE_FILENAME@','BOX3D_to_LWGEOM'
Paul Ramsey wrote:
> Charlie Savage wrote:
>> As an aside, its not obvious to me how to actually fix this bug.
>> Somehow the conversion from Box2D/Box3D to geometry needs to figure
>> out if the bbox has 0 width and/or 0 height and if so create a Point
>> instead of a Polygon.
> The problem will live in the function that casts from Box* to GEOMETRY.
>  PostgreSQL does automatic casting, so
> Extent(GEOMETRY) return BOX*
> Centroid(GEOMETRY) returns GEOMETRY
> PostgreSQL will rewrite Centroid(Extent()) to Centroid(Box2Geom(Extent())
> P.
   Paul Ramsey
   Refractions Research
   http://www.refractions.net
   Phone: 250-383-3022
   Cell: 250-885-0632
