[postgis-users] How to get the centroid of an bounding box using st_extent
Martin Davis
mbdavis at refractions.net
Wed Sep 19 17:44:30 PDT 2007
Well, I'm slightly embarassed to admit that for the case of an envelope
for a horizontal or vertical line, JTS actually returns an invalid
polygon. (For point envelopes however it does return a Point geometry).
There's a couple of reasons for this. One is that the OGC SFS seems to
imply that when returning envelopes as a Geometry, a Polygon should be
returned. The other is simply that the original JTS behaviour was to
always return a Polygon, and when the code was enhanced to return Points
for zero-area envelopes, the linear case was omitted.
In its defence I'll point out that in my experience working with JTS it
is *very* rare to need to obtain a Geometry as an envelope. Usually
when doing "Envelopey" kinds of things it is much faster, simpler, and
more robust to simply work with actual Envelope objects.
Charlie Savage wrote:
> Paul,
>> Hmmm... for an linear envelope would returning a linestring not make
>> more sense?
> That does raise another question.
> select astext(envelope('LINESTRING(0 0, 0 10)'))
> "POLYGON((0 0,0 10,0 10,0 0,0 0))"
> select valid(envelope('LINESTRING(0 0, 0 10)'))
> false
> Should envelope should do the same? What does JTS/GEOS do in this case?
> Charlie
> postgis-users mailing list
Martin Davis
Senior Technical Architect
Refractions Research, Inc.
(250) 383-3022
