[postgis-users] Gist and points
Obe, Regina robe.dnd at cityofboston.gov
Thu Sep 20 07:17:00 PDT 2007
I checked my point records and they don't have them either.  I'm
guessing that there is no benefit to having a bbox on a point geometry
since a point is lighter than the bbox.  So I'm guessing when you put a
gist index on point geometries, it doesn't wrap a bbox around it as it
does with polygons.
I found this old postgis newgroup item too on further inspection.  I
assume this still applies.
http://postgis.refractions.net/pipermail/postgis-users/2005-October/0095
50.html
-----Original Message-----
From: postgis-users-bounces at postgis.refractions.net
[mailto:postgis-users-bounces at postgis.refractions.net] On Behalf Of
Stephen Crawford
Sent: Thursday, September 20, 2007 9:43 AM
To: 'PostGIS Users Discussion'
Subject: [postgis-users] Gist and points
I have a db with a few million points.  I noticed that hasbbox(the_geom)
false for these points.  Does the gist index require that each these
geometries have a bbox?  Should I add a bbox?
Thanks,
Steve
Stephen Crawford
Center for Environmental Informatics
The Pennsylvania State University
postgis-users mailing list
postgis-users at postgis.refractions.net
http://postgis.refractions.net/mailman/listinfo/postgis-users
The substance of this message, including any attachments, may be
confidential, legally privileged and/or exempt from disclosure
pursuant to Massachusetts law. It is intended
solely for the addressee. If you received this in error, please
contact the sender and delete the material from any computer.
