[postgis-users] Union of 7 datasets
Andreas Laggner
andreas.laggner at fal.de
Wed Sep 26 03:45:34 PDT 2007
Hi Regina,
i am mixed up a little bit because i had the correct geometries in
Quantum GIS but i cannot reproduce how i get them?! I thought it was the
query with collect (i sent to you) but in a new operation i got another
result with this query (unfortunately with wrong results - the
overlapping polygons are not seperated)????
Right now i am working on the suggestion from Kevin
(http://postgis.refractions.net/support/wiki/index.php?ExamplesOverlayTables
) - and one thing a can already say: It is at least 5 times slower than
your query :-)
cu Andreas
Obe, Regina schrieb:
> Not sure I quite understand the question. You mean to store these 3 geometries separately so you can color code as needed or overlay as needed?
> In that case you would have 3 separate geometry fields
> intersection(ffh_rep.the_geom, spa_rep.the_geom) As geomintersection, ffh_rep.the_geom As ffh_geom, spa_rep.the_geom As spa_geom
> For the ones where there is only udo or kai then I guess you can fill in the same geometry for all geometry fields.
> and then overlay them on your map as separate layers as needed
> or if you mean you just want it to look like figure 1 but not necessarily color coded, then you would do
> collect(ffh_rep.the_geom, spa_rep.the_geom) as geomcollection
> Hope that helps,
> Regina
> -----Original Message-----
> From: postgis-users-bounces at postgis.refractions.net [mailto:postgis-users-bounces at postgis.refractions.net] On Behalf Of Andreas Laggner
> Sent: Thursday, August 30, 2007 7:24 AM
> To: PostGIS Users Discussion
> Subject: Re: [postgis-users] Union of 7 datasets
> Moin Regina,
> the query you suggested is a very big step forward, but it does not
> exactly what i want to have ;-) ... it seems to me i will need an
> intersection in one part and not a geomunion!! But i want to ask you:
> what it does correctly: I now have a union of all geometries from both
> source datasets.
> If i have a single udo (ffh_rep) that intersects no kai (spa_rep) the
> row only has the attributes from udo. Same thing i have with single kai.
> That is all correct.
> BUT: If udo and kai intersects i will not have new polygons!! For
> example: blue is udo (or ffh_rep) and yellow is kai (or spa_rep). I want
> to have three polygons than with blue only the attributes from udo,
> yellow only the attributes from kai AND the intersection, polygon number
> 3, the green one (blue with yellow points) with the attributes from udo
> and kai (figure1). And now i have one Polygon having the attributes from
> udo and kai (figure2).
> figure1:
> figure1
> figure2:
> figure2
> My query:
> drop table natura2000;
> create table natura2000
> (ffh_name character varying(80),ffh_land character varying(3),ffh
> smallint,ffh_id smallint,
> spa_name character varying(80),spa_land character varying(3),spa
> smallint,spa_id smallint)
> with oids;
> select
> addgeometrycolumn('','natura2000','newgeom','31467','MULTIPOLYGON',2);
> alter table natura2000 drop constraint enforce_geotype_newgeom;
> insert into natura2000
> (ffh_name,ffh_land,ffh,ffh_id,spa_name,spa_land,spa,spa_id,newgeom)
> select ffh_rep.ffh_name,ffh_rep.ffh_land,ffh_rep.ffh,ffh_rep.ffh_id,
> spa_rep.spa_name,spa_rep.spa_land,spa_rep.spa,spa_rep.spa_id,
> geomunion(ffh_rep.the_geom, spa_rep.the_geom) as newgeom
> from ffh_rep inner join spa_rep
> on (ffh_rep.the_geom && spa_rep.the_geom and
> intersects(ffh_rep.the_geom, spa_rep.the_geom))
> union all
> -- the second select gives you ffh_reps that have no spa_reps - your 15
> null as spa_name, null as spa_land, null as spa, null as spa_id,
> ffh_rep.the_geom as newgeom
> from ffh_rep left join spa_rep
> where spa_rep.the_geom is null
> union all
> -- and the 3rd gives you spa_reps that have no ffh_reps. - your 40
> select null as ffh_name, null as ffh_land, null as ffh, null as ffh_id,
> spa_rep.the_geom AS newgeom
> from spa_rep left join ffh_rep
> where ffh_rep.the_geom is null;
> Cheers Andreas
>> Andreas,
>> You would use the SQL UNION predicate like shown below (actually
>> slight correction - it is speedier to use UNION ALL especially when
>> you know there will not be dupiclates since it saves the processing of
>> sorting to get a distinct UNION does an implicit distinct) - so I
>> have corrected below.
>> - - I happened to insert comments in between which may have confused
>> you, but you should be able to run the whole thing as one statement or
>> if you prefer because of speed issues run each insert separately.
>> So would be
>> INSERT INTO sometable(field1, field2,field3,field4, newgeom)
>> SELECT udo.field1, udo.field2, kai.field3, kai.field4,
>> geomunion(udo.the_geom, kai.the_geom) AS newgeom
>> FROM udo INNER JOIN kai ON (udo.the_geom && kai.the_geom AND
>> intersects(udo.the_geom, kai.the_geom))
>> UNION ALL
>> -- the second select gives you udos that have no kais - your 15
>> SELECT udo.field1, udo.field2, NULL As field3, NULL As field4,
>> udo.the_geom AS newgeom
>> FROM udo LEFT JOIN kai ON (udo.the_geom && kai.the_geom AND
>> WHERE kai.the_geom IS NULL
>> UNION ALL
>> -- and the 3rd gives you kais that have no udos. - your 40
>> SELECT NULL As field1, null As field2, kai.field3, kai.field4,
>> kai.the_geom AS newgeom
>> FROM kai LEFT JOIN udo ON (udo.the_geom && kai.the_geom AND
>> WHERE udo.the_geom IS NULL;
>> ----If FULL JOIN were to work (which in theory it should, but doesn't
>> seem to with Postgis functions (HINT HINT: would be nice if
>> that worked and can be easily fixed (but sadly I think the issue is
>> deeper than Postgis and Geos) - you could write the above much simpler as)
>> COALESCE(geomunion(udo.the_geom, kai.the_geom), udo.the_geom,
>> FROM udo FULL JOIN kai ON (udo.the_geom && kai.the_geom AND
>> Now if you have a lot of these and the tables are very similar in
>> nature and named in a predictable way then the way I usually handle it
>> is to write a pgsql function that dynamically generates the SQL
>> statement to execute either via a FOR loop and then executes the built
>> SQL or set of SQL statements or you could do a similar thing in some
>> scripted language like perl or php.
>> I take it SQL and pgsql and all that is fairly new to you so it might
>> be worthwhile (even though its a lot of typing) to do it the long cut
>> and paste way if nothing more than an exercise to get a feel of how
>> this all works and visualize the patterns at play.
>> I don't get the sense that I comprehend your full problem.
>> Unfortunately I don't have any experience with ArcGIS/ArcView ways of
>> doing things, so I'm not quite sure if there is an equivalent way in
>> PostGIS/PostgreSQL world of doing the same kind of thing and what
>> exactly that thing is you are doing in ArcGIS.
>> Union has 3 meanings in PostGIS/PostgreSQL (actually stuff your
>> favorite spatial/DB here - all non-trivial spatial relational dbs
>> behave more or less the same)
>> 1) unioning of record sets (standard ANSI SQL UNION/UNION ALL) - which
>> is simply a way of stringing together a bunch of selects into a
>> single result set as shown above
>> 2) unioning of 2 geometry fields like shown above with geomunion
>> 3) Aggregate geomunion - aggregate variant of the above geomunion
>> function that groups and unions a whole setof geometries together but
>> requires you are grouping by some field or set of fields).
>> I must also mention there is collect (non-aggregate and aggregate
>> function) which often times is just as effective as the geomunion and
>> in general much faster processor wise.
>> Hope that helps,
>> Regina
>> Andreas Laggner
>> Sent: Tuesday, August 28, 2007 9:13 AM
>>> Sounds like you would have to go with a full join type thing with
>> workaround I described below (last example). So If I understand you
>> correctly then something like this -
>>> --the first select gives you those records in both tables your 25 udokai
>>> UNION
>>> UNION
>>> SELECT nul As field1, null As field2, kai.field3, kai.field4,
>>> Unioned together you should get
>>> 25 + 15 + 40 = ? 80
>>> Hope that helps,
>>> Regina
>> UFF - that seems to be a complex question, a comprehensive operation and
>> a lot to type too!!! Thanks a million - i would have spent many time to
>> find out this query by myself! Ok..... how can i perform your "UNION": I
>> would just insert my selects one after another in one new table - will
>> that work well?
>> I want to aggregate around 20 datasets this way!? Do you know a method
>> to operate with more datasets (for example 7) in a effektiv manner and
>> not to do this three selects 6 times?
>> AND: Am i totally wrong with my aims? It seems to me that is an exotic
>> think to do with PostGis, but our projects/problems require to aggregate
>> datasets in almost all cases (around 90%) and that is exactly what one
>> of the basic functions "Union" in ArcView already carried out ten years
>> ago. So i would exspect there is a function to perform this operation
>> easier!? .....i just wonder.....
>> cheers Andreas
>> Andreas Laggner
>>> Sent: Tuesday, August 28, 2007 7:28 AM
>>>> BASIC TRICK: If you want to get all records with no matching
>> including those that match - put what you would normally put in your
>> WHERE clause in the JOIN clause and use a LEFT JOIN.
>>> ok - it seems to me i need some coaching......Yes, I want to get all
>>> records with no matching including those that match, but i also want to
>>> dissect the polygons that matches. I will try to explain again just to
>>> be sure you understood my aims: I have 20 polygons in udo and 50 in kai.
>>> 10 from kai are intersecting 5 from udo to 25 new polygons i call udokai
>>> (because they have attributes from udo AND kai). My result should have:
>>> 15 polygons with attributes only from udo, 40 polygons with attributes
>>> only from kai AND 25 with attributes from udo and kai! In most cases i
>>> want to do such a operation because i want to aggregate (spatial
>>> correct) different datasets!
>>> Which example from you fits best for this aim? I did not find any
>>> information on how left join works on the postgis or postgresql
>> reference...
>>>> Unfortunately as I have come across before if you need an either or
>> (if in table 1 or table 2 - ideally you would use a FULL JOIN but for
>> some reason Postgres chokes when you use postgis functions in the FULL
>> JOIN clause for the cases I have tried). In that case you need a
>> workaround using a set of UNIONS.
>>>> Simplest case - get all records in g1 one or union of g1 and g2
>> that intersect
>>>> NOTE: COALESCE is an ANSI SQL function that will return the first
>> non-null - when you do a geomunion of a geometry and null you get null
>> which is why we need COALESCE
>>>> SELECT g1.field1, g1.field2, COALESCE(geomunion(g1.the_geom,
>> g2.the_geom), g1.the_geom) AS newgeom
>>>> FROM g1 LEFT JOIN g2 ON (g1.the_geom && g2.the_geom AND
>> intersects(g1.the_geom, g2.the_geom))
>>>> Either of case - get all geometries in g1 or g2 or union if there
>> is a match - workaround for full joins not working right
>>>> SELECT g1.field1, g1.field2, geomunion(g1.the_geom, g2.the_geom) AS
>> newgeom
>>>> FROM g1 INNER JOIN g2 ON (g1.the_geom && g2.the_geom AND
>>>> UNION
>>>> SELECT g1.field1, g1.field2, g1.the_geom AS newgeom
>>>> WHERE g2.the_geom IS NULL
>>>> UNION
>>>> SELECT g1.field1, g1.field2, g2.the_geom AS newgeom
>>>> FROM g2 LEFT JOIN g1 ON (g1.the_geom && g2.the_geom AND
>>>> WHERE g1.the_geom IS NULL
>>>> Hope that helps,
>>>> Regina
>> Andreas Laggner
>>>> Sent: Thursday, August 23, 2007 11:32 AM
>>>>> Oh the g1 g2 .. was just for example - I don't actually call my
>> tables meaningless names like that.
>>>>> You should be doing a join on something or have a where clause
>> unless one of your tables has only one record. Otherwise you are
>> doing what is called a CROSS JOIN (cartesian product) which gives you
>> an nxm records where n is the number of records in your first table
>> and m is the number in second table. This is generally a big NO NO.
>> In certain rare cases you do want to do something like that, but is
>> usually the exception.
>>>> I think the records in my targed table must be added (more or less) and
>>>> not multiplied! My Aim is a table that contains the areas of all the 7
>>>> sourcetables and the information which refuges are inside and wich not.
>>>> Perhaps i must use the intersection!? If i do my query with a gist like
>>>> this: where t1.the_geom && t2.the_geom; than the operation is very fast
>>>> (about one minute) but i only have the Polygons covered by BOTH
>>>> datasets, and i want to have as well those, which are covered by one
>>>> dataset only!! But my operation without the where clause runs for 4
>>>> hours now - that shows me there is something wrong ;-)
>>>>> Its hard for me to tell if you need a cartesian product in this
>> case since I'm not quite sure what for example nature and biosphere
>> represent. I would guess that is wrong and you should first figure
>> out which sets of say nature records you need to geomunion with
>> biosphere and then join by that field or set of fields.
>>>>> It would help a bit if you could provide some sample questions you
>> expect to answer with your statistical analysis. My guess is you may
>> be better off with more than one table.
>>>> Sample question: give me all areas (all polygons) from germany where
>>>> landuse=arable land and soils=good and precipitation>600 and any (of 7)
>>>> reserves and so on.......
>>>> I need the values in my table to calculate the potential yield or other
>>>> things...
>>>> And i want to analyse such questions with a statistical software (SAS),
>>>> so it seems to me i need one table to import in SAS (or to query from
>>>> SAS directly to the postgresql).
>>>> Thanks for your help, i will be back in my office in
>> Monday.......Andreas
>>>>> Which structure is best really boils down to what questions you
>> hope to answer because one approach may make one question easy and
>> fast and another question slow and cumbersome.
>>>>> Hope that helps,
>>>>> Regina
>> Andreas Laggner
>>>>> Sent: Thursday, August 23, 2007 10:04 AM
>>>>>> Andreas,
>>>>>> It would help to know what your table structure looks like and
>> why do you want to put them all in a single geometry?
>>>>> My table structures are a little bit different. I want to have
>> them in a
>>>>> single geometry to intersect them with other data and built a large
>>>>> table to run statistics over it (production site analysis over
>> germany).
>>>>>> I'm imaging you are you doing something like
>>>>>> SELECT g1.somefield, geomunion(geomunion(g1.the_geom,
>> g2.the_geom), g3.the_geom)
>>>>>> FROM g1 INNER JOIN g2 on g1.somefield = g2.somefield INNER JOIN
>> g3 on g2.somefield = g3.somefield
>>>>>> GROUP BY g1.somefield
>>>>> That´s an interesting method with inner join..why go you call your
>>>>> tables g1. g2. and so on?
>>>>> That´s my method i am using right now (geomunion 1 to 3 from 6), seems
>>>>> to be a pedestrian method :-(
>>>>> (ffh_name character varying(80), ffh_land character
>> varying(3), ffh
>>>>> smallint, ffh_id smallint,
>>>>> spa_name character varying(80), spa_land character
>> varying(3), spa
>>>>> smallint, spa_id smallint) with oids;
>>>>> select
>> addgeometrycolumn('','natura2000','the_geom','31467','MULTIPOLYGON',2);
>>>>> alter table natura2000 drop constraint enforce_geotype_the_geom;
>>>>> select
>> t1.ffh_name,t1.ffh_land,t1.ffh,t1.ffh_id,t2.spa_name,t2.spa_land,t2.spa,t2.spa_id,
>>>>> geomunion(t1.the_geom, t2.the_geom)
>>>>> from ffh_rep t1, spa_rep t2;
>>>>> create table sg71
>> varying(3), ffh
>> varying(3), spa
>>>>> smallint, spa_id smallint,
>>>>> bio_name character varying(70), bio smallint, bio_id
>> smallint) with
>>>>> oids;
>>>>> select
>> addgeometrycolumn('','sg71','the_geom','31467','MULTIPOLYGON',2);
>>>>> alter table sg71 drop constraint enforce_geotype_the_geom;
>>>>> insert into sg71
>>>>> select t1.ffh_name, t1.ffh_land, t1.ffh, t1.ffh_id, t1.spa_name,
>>>>> t1.spa_land, t1.spa, t1.spa_id,
>>>>> t2.name,t2.bio,t2.bio_id,geomunion(t1.the_geom,
>> t2.the_geom)
>>>>> from natura2000 t1, biosphere t2;
>>>>> create table sg72
>>>>> (ffh_name character varying(80), ffh_land character varying(3),
>>>>> ffh smallint, ffh_id smallint,
>>>>> spa_name character varying(80), spa_land character varying(3), spa
>>>>> bio_name character varying(70), bio smallint, bio_id smallint,
>>>>> np_name character varying(60), np smallint, np_id smallint)
>> with oids;
>>>>> select
>> addgeometrycolumn('','sg72','the_geom','31467','MULTIPOLYGON',2);
>>>>> alter table sg72 drop constraint enforce_geotype_the_geom;
>>>>> insert into sg72
>>>>> t1.bio_name,t1.bio,t1.bio_id,t2.np_name,t2.np,t2.np_id,
>>>>> from sg71 t1, np t2;
>>>>> AND SO ON......
>>>>>> or
>>>>>> SELECT g1.somefield, geomunion(gt.the_geom)
>>>>>> FROM (SELECT somefield, the_geom FROM g1 UNION SELECT somefield,
>> the_geom FROM g2 ...) gt
>>>>>> GROUP BY gt.somefield
>>>>>> If I have 7 different tables that have pretty much the same
>> structure, but for logistical or other technical reasons (such as each
>> has additional attributes distinct from one another), I need to keep
>> them as separate tables, then I usually use inherited tables for that.
>> That way when I need to join all datasets at once, I can simply query
>> the parent table and it will automatically drill down to the child
>> tables. Not sure if that helps more than it confuses your situation.
>>>>>> Then instead of the above I can simply do
>>>>>> SELEG myparenttable.somefield, geomunion(myparenttable.the_geom)
>>>>>> FROM myparenttable
>>>>>> GROUP by gh.somefield
>>>>> ok - i have to think about your suggestions......that´s my second week
>>>>> with postgis.
>>>>> Can you tell me from my SQL-Statements which method will be best? So i
>>>>> try to understand that one.....
>>>>> Thanks for your reply!!!
>>>>>> Hope that helps,
>>>>>> Regina
>> Andreas Laggner
>>>>>> Sent: Thursday, August 23, 2007 9:11 AM
>>>>>> To: PostGis_Mailinglist
>>>>>> Subject: [postgis-users] Union of 7 datasets
>>>>>> Hi users,
>>>>>> i want to put together 7 datasets to have all the different
>> refuges in
>>>>>> one table (and in one geometry). Am i doing right with 6 times
>> geomunion
>>>>>> (that´s much to type with all the attributes) or is there a more
>>>>>> effective way?
>>>>>> cheers Andreas
>> Dipl. Geoökologe Andreas Laggner
>> Institut für Ländliche Räume (LR)
>> Bundesforschungsanstalt für Landwirtschaft (FAL)
>> Institute of Rural Studies
>> Federal Agricultural Research Centre (FAL)
>> Bundesallee 50
>> D-38116 Braunschweig
>> Tel.: (+49) (0)531 596 5515
>> Fax: (+49) (0)531 596 5599
>> E-mail: andreas.laggner at fal.de
>> Homepage: http://www.lr.fal.de/
>> postgis-users mailing list
>> postgis-users at postgis.refractions.net
>> http://postgis.refractions.net/mailman/listinfo/postgis-users
>> *The substance of this message, including any attachments, may be
>> confidential, legally privileged and/or exempt from disclosure
>> pursuant to Massachusetts law. It is intended solely for the
>> addressee. If you received this in error, please contact the sender
>> and delete the material from any computer. *
Bundesallee 50
