[postgis-users] Problems installing PostGIS on Red Hat EL 5
Paul Ramsey
pramsey at cleverelephant.ca
Wed Apr 2 08:42:18 PDT 2008
In addition to adding GEOS 3, you need to complete REMOVE GEOS 2.2.
Are you sure your system is clean? I'm pretty sure I scraped this
version-dependent stuff out of postgis-svn a couple days ago, so all I
can think of is that you successfully built against the new version of
GEOS but your system is still trying to link against the old version
of GEOS.
P
On Sat, Feb 2, 2008 at 8:49 AM, Paragon <lr at pcorp.us> wrote:
> Jeshua,
> Thanks again. Otool doesn't exist on RedHat evidentally, but the equivalent
> appears to be ldd
> So running
> ldd -d /usr/lib/pgsql/liblwgeom.so | grep libgeos
> Gives me
> libgeos_c.so.1 => /usr/lib/libgeos_c.so.1 (0x00519000)
> libgeos.so.2 => /usr/lib/libgeos.so.2 (0x00c71000)
> undefined symbol: SPI_tuptable (/usr/lib/pgsql/liblwgeom.so)
> undefined symbol: CurrentMemoryContext (/usr/lib/pgsql/liblwgeom.so)
> undefined symbol: my_exec_path (/usr/lib/pgsql/liblwgeom.so)
> undefined symbol: textout (/usr/lib/pgsql/liblwgeom.so)
> undefined symbol: SPI_processed (/usr/lib/pgsql/liblwgeom.so)
> undefined symbol: default_statistics_target
> On further inspection of what /usr/lib/libgeos.so.2
> ls -ahn /usr/lib/libgeos.so.2
> Gives me
> /usr/lib/libgeos.so.2 -> libgeos.so.2.2.3
> Ls -ahn /usr/lib/libgeos.so.2 ---> libgeos.so.1.1.1
> So I guess that is the root of my problem. To try to overcome this
> predicament - I deleted those symlinks
> rm /usr/lib/libgeos.so.2
> rm /usr/lib/libgeos_c.so.1
> cp /usr/local/lib/liggeos.so /usr/lib/libgeos.so.3.0.0
> cp /usr/local/lib/libgeos_c.so /usr/lib/libgeos_c.so.3.0.0
> ln -s /usr/lib/libgeos.so.3.0.0 /usr/lib/libgeos.so.2
> ln -s /usr/lib/libgeos.so.3.0.0 /usr/lib/libgeos_c.so.1
> service postgresql restart
> ---Well I guess that got a bit warmer - now I am getting this error
> ERROR: could not load library "/usr/lib/pgsql/liblwgeom.so":
> /usr/lib/pgsql/liblwgeom.so: undefined symbol: GEOSUnion
> SQL state: 58P01
> Context: SQL statement "SELECT postgis_lib_version()"
> PL/pgSQL function "postgis_full_version" line 11 at SQL statement
> Thanks,
> Regina
> -----Original Message-----
> From: Jeshua Lacock [mailto:jeshua at 3DTOPO.com]
> Sent: Wednesday, April 02, 2008 2:52 AM
> To: PostGIS Users Discussion; Paragon Corporation
> Subject: Re: [postgis-users] Problems installing PostGIS on Red Hat EL 5
> > GEOSTopologyPreserveSimplify
> > CONTEXT: SQL statement "SELECT postgis_lib_version()"
> On Apr 2, 2008, at 12:28 AM, Paragon Corporation wrote:
> > ./configure --with-pgsql=/usr/bin/pg_config --with-geos=
> > /usr/local/bin/geos-config
> Run 'otool -L' on liblwgeom to see if it is linked to geos:
> otool -L /usr/lib/pgsql/liblwgeom.so | grep libgeos
> You should see a line with (Or something similar):
> /usr/local/lib/libgeos_c.1.so (compatibility version 6.0.0, current
> version 6.1.0)
> If you don't see it needs to be linked to it.
> P.S. I am on Mac OS X, so I am not sure if RedHat has otool, but I think it
> does...
> Yours,
> Jeshua Lacock
> Founder/Programmer
> 3DTOPO Incorporated
> <http://3DTOPO.com>
> Phone: 877.240.1364
> postgis-users mailing list
