[postgis-users] Problems installing PostGIS on Red Hat EL 5
Paragon lr at pcorp.us
Wed Apr 2 12:29:52 PDT 2008
Thanks Paul.  Yes that was it and linking to the geos 3.0.0 fixed that issue
- just my inexperience with RedHat I think is the big culprit.  I'm hesitant
to completely blow out the old geos since there is a bunch of stuff I'm not
familiar with on this box that is probably linking to it.
I haven't throughly tested yet with the postgis-svn but realize I'm probably
going into some not so chartered territories especially since the
Svn seems to be in a state of flux just looking at the postgis-dev
newsgroup.
You know off hand anything we should be aware of?  I'm building a completely
clean database now and soon will be loading tons of data into it and doing
all sorts of spatial acrobatic maneuvers so we'll let you know if we see
anything strange with the 8.3.1 and postgis-svn (1.3.3) mix.
You mentioned something with ST_Contains on Postgis-dev, but my simple
select st_contains('POINT(1 1)', 'POINT(1 1)') -> true seems to work okay
ST_Union as far as I can tell seems to be working too (well its not crashing
the postgresql service anymore at anyrate) though seems
So right now not sure if whatever the issue is with ST_Contains is  fixed or
that's just what I get for eavesdropping on not so private conversations.
Thanks,
Regina
-----Original Message-----
From: postgis-users-bounces at postgis.refractions.net
[mailto:postgis-users-bounces at postgis.refractions.net] On Behalf Of Paul
Ramsey
Sent: Wednesday, April 02, 2008 11:42 AM
To: PostGIS Users Discussion
Subject: Re: [postgis-users] Problems installing PostGIS on Red Hat EL 5
In addition to adding GEOS 3, you need to complete REMOVE GEOS 2.2.
Are you sure your system is clean? I'm pretty sure I scraped this
version-dependent stuff out of postgis-svn a couple days ago, so all I can
think of is that you successfully built against the new version of GEOS but
your system is still trying to link against the old version of GEOS.
P
On Sat, Feb 2, 2008 at 8:49 AM, Paragon <lr at pcorp.us> wrote:
> Jeshua,
>  Thanks again.  Otool doesn't exist on RedHat evidentally, but the
> equivalent  appears to be ldd
>  So running
>  ldd -d  /usr/lib/pgsql/liblwgeom.so | grep libgeos
>  Gives me
>         libgeos_c.so.1 => /usr/lib/libgeos_c.so.1 (0x00519000)
>         libgeos.so.2 => /usr/lib/libgeos.so.2 (0x00c71000)  undefined
> symbol: SPI_tuptable  (/usr/lib/pgsql/liblwgeom.so)  undefined symbol:
> CurrentMemoryContext  (/usr/lib/pgsql/liblwgeom.so)  undefined symbol:
> my_exec_path  (/usr/lib/pgsql/liblwgeom.so)
>  undefined symbol: textout       (/usr/lib/pgsql/liblwgeom.so)
>  undefined symbol: SPI_processed (/usr/lib/pgsql/liblwgeom.so)
> undefined symbol: default_statistics_target
>  On further inspection of what /usr/lib/libgeos.so.2  ls -ahn
>  Gives me
>  /usr/lib/libgeos.so.2 -> libgeos.so.2.2.3
>  Ls -ahn /usr/lib/libgeos.so.2 ---> libgeos.so.1.1.1
>  So I guess that is the root of my problem.  To try to overcome this
> predicament - I deleted those symlinks  rm /usr/lib/libgeos.so.2  rm
>  cp /usr/local/lib/liggeos.so /usr/lib/libgeos.so.3.0.0  cp
> /usr/local/lib/libgeos_c.so /usr/lib/libgeos_c.so.3.0.0  ln -s
> /usr/lib/libgeos.so.3.0.0 /usr/lib/libgeos.so.2  ln -s
> /usr/lib/libgeos.so.3.0.0 /usr/lib/libgeos_c.so.1  service postgresql
> restart
>  ---Well I guess that got a bit warmer - now I am getting this error
>  ERROR: could not load library "/usr/lib/pgsql/liblwgeom.so":
>  /usr/lib/pgsql/liblwgeom.so: undefined symbol: GEOSUnion  SQL state:
> 58P01
>  Context: SQL statement "SELECT postgis_lib_version()"
> PL/pgSQL function "postgis_full_version" line 11 at SQL statement
>  Thanks,
>  Regina
>  From: Jeshua Lacock [mailto:jeshua at 3DTOPO.com]
>  Sent: Wednesday, April 02, 2008 2:52 AM
>  To: PostGIS Users Discussion; Paragon Corporation
> EL 5
>  > GEOSTopologyPreserveSimplify
>  > CONTEXT:  SQL statement "SELECT postgis_lib_version()"
>  On Apr 2, 2008, at 12:28 AM, Paragon Corporation wrote:
>  > ./configure --with-pgsql=/usr/bin/pg_config  --with-geos=  >
> /usr/local/bin/geos-config
>  Run 'otool -L' on liblwgeom to see if it is linked to geos:
>         otool -L /usr/lib/pgsql/liblwgeom.so | grep libgeos
>  You should see a line with (Or something similar):
>         /usr/local/lib/libgeos_c.1.so (compatibility version 6.0.0,
> current  version 6.1.0)
>  If you don't see it needs to be linked to it.
>  P.S. I am on Mac OS X, so I am not sure if RedHat has otool, but I
> think it  does...
>  Yours,
>  Jeshua Lacock
>  Founder/Programmer
>  3DTOPO Incorporated
>  <http://3DTOPO.com>
>  Phone: 877.240.1364
>  _______________________________________________
>  postgis-users mailing list
>  postgis-users at postgis.refractions.net
>  http://postgis.refractions.net/mailman/listinfo/postgis-users
