[postgis-users] ST_Union throws TopologyException found non-noded intersection between...
Rainer Spittel
rainer.spittel at terralink.co.nz
Wed Apr 2 20:05:22 PDT 2008
I have a problem aggregating a parcel multipolygon dataset. I want to
join all parcel geometries (multipolygon) via their road names. All
geometries have the same projection and are valid (checked via PostGIS).
I am running a sql-statement like:
select road, suburb, town, tla, ST_UNION(the_geom) as the_geom
into locations
from property
group by road, suburb, town, tla;
and get this error message after a while:
NOTICE: TopologyException: found non-noded intersection between
3.15383e+06 5.67709e+06, 3.15382e+06 5.67704e+06 and 3.15382e+06
5.67698e+06, 3.15382e+06 5.67704e+06 3.15382e+06 5.67704e+06
ERROR: GEOS union() threw an error!
To see if I have a general data problem, I reduced the polygon
complexity to points via ST_POINTONSURFACE, which works fine. But using
polygons, the statements just fails.
This is the server configuration:
OS: Linux Fedora
DB: Postgres 8.2.5
-> PostGIS 1.3.2
-> GEOS 3.0.0 (release version)
-> Proj-4.4.9
I run out of ideas and I am looking forward for any help.
Cheers
Rainer
