[postgis-users] ST_Union throws TopologyException found non-noded intersection between...
Mark Cave-Ayland
mark.cave-ayland at siriusit.co.uk
Thu Apr 3 07:15:56 PDT 2008
On Thursday 03 April 2008 04:05:22 Rainer Spittel wrote:
> Hi,
> I have a problem aggregating a parcel multipolygon dataset. I want to
> join all parcel geometries (multipolygon) via their road names. All
> geometries have the same projection and are valid (checked via PostGIS).
> I am running a sql-statement like:
> select road, suburb, town, tla, ST_UNION(the_geom) as the_geom
> into locations
> from property
> group by road, suburb, town, tla;
> and get this error message after a while:
> NOTICE: TopologyException: found non-noded intersection between
> 3.15383e+06 5.67709e+06, 3.15382e+06 5.67704e+06 and 3.15382e+06
> 5.67698e+06, 3.15382e+06 5.67704e+06 3.15382e+06 5.67704e+06
> ERROR: GEOS union() threw an error!
> To see if I have a general data problem, I reduced the polygon
> complexity to points via ST_POINTONSURFACE, which works fine. But using
> polygons, the statements just fails.
> This is the server configuration:
> OS: Linux Fedora
> DB: Postgres 8.2.5
> -> PostGIS 1.3.2
> -> GEOS 3.0.0 (release version)
> -> Proj-4.4.9
> I run out of ideas and I am looking forward for any help.
> Cheers
> Rainer
Hi Rainer,
Have you checked the validity of your polygons using ST_IsValid()?
HTH,
Mark.
Mark Cave-Ayland
Sirius Corporation - The Open Source Experts
http://www.siriusit.co.uk
T: +44 870 608 0063
