[postgis-users] Loading Tiger2007fe data - Thoughts on using inherited tables
Stephen Woodbridge
woodbri at swoodbridge.com
Fri Apr 4 09:56:43 PDT 2008
Stephen,
Changing the subject on this thread.
Have look into using inherited tables? This would allow you to have a
nation view or a state view of the county data. View being used in the
literal not postgres in this case.
create table us_tiger.blocks ....;
create table ST_tiger.blocks inherits us_tiger.blocks;
create table STCCC_tiger.blocks inherits ST_tiger.blocks;
load data into STCCC_tiger.blocks
now you can query on any level of these. Displaying in mapserver at the
national level is as easy as a LAYER that references us_tiger.blocks.
You have to set up indexes, I'm not sure what the best we to do this is.
This scheme also allows you to drop and replace one STCCC_tiger.blocks
table with new data and it is magically integrated back into the model.
Thoughts?
-Stephen Woodbridge
http://imaptools.com/
