[postgis-users] Loading Tiger2007fe data - Thoughts on using inherited tables
Stephen Frost
sfrost at snowman.net
Fri Apr 4 11:10:11 PDT 2008
Stephen,
* Stephen Woodbridge (woodbri at swoodbridge.com) wrote:
> Have look into using inherited tables? This would allow you to have a
> nation view or a state view of the county data. View being used in the
> literal not postgres in this case.
Honestly, I havn't. I'm really not all that keen on inheiritance in PG
anyway. What I'm probably going to do instead though, so you know, is
combine all of the county-level data into state-level tables, and then
create a view across the state tables to generate a national table.
This partitioning should make things go pretty quickly, imv. I'll
certainly let folks know if I'm happy with it or not.
Thanks,
Stephen
Desc: Digital signature
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20080404/c050f100/attachment.pgp>
