[postgis-users] Loading Tiger2007fe data - Thoughts on using inherited tables
Stephen Frost
sfrost at snowman.net
Fri Apr 4 11:40:27 PDT 2008
* Paul Ramsey (pramsey at cleverelephant.ca) wrote:
> Look at "constraint exclusion" as a strategy...
Yes, certainly this approach will be taking advantage of constraint
exclusion.
> http://www.postgresql.org/docs/8.1/interactive/ddl-partitioning.html
> It actually *does* use inheritance, but it does fancy query re-writes too.
It can also be done with a simple view, and since we're not going to be
updating the tiger tables, or adding new rows, or adding new tables,
it's alost simpler/easier/cleaner to just create the necessary views
once (with the correct where clauses with constant values) than set up
inheiritance and whatnot.
Thanks,
Stephen
> On Fri, Apr 4, 2008 at 11:10 AM, Stephen Frost <sfrost at snowman.net> wrote:
> > Stephen,
> > * Stephen Woodbridge (woodbri at swoodbridge.com) wrote:
> > > Have look into using inherited tables? This would allow you to have a
> > > nation view or a state view of the county data. View being used in the
> > > literal not postgres in this case.
> > Honestly, I havn't. I'm really not all that keen on inheiritance in PG
> > anyway. What I'm probably going to do instead though, so you know, is
> > combine all of the county-level data into state-level tables, and then
> > create a view across the state tables to generate a national table.
> > This partitioning should make things go pretty quickly, imv. I'll
> > certainly let folks know if I'm happy with it or not.
> > Thanks,
> > Stephen
> > -----BEGIN PGP SIGNATURE-----
> > Version: GnuPG v1.4.6 (GNU/Linux)
> > iD8DBQFH9m8DrzgMPqB3kigRAhj1AJ9upuYPkTNrzLQWv74QW1hewjtxJQCfXCZy
> > feifOYH9dPLDphnwVOd788M=
> > =izsS
> > -----END PGP SIGNATURE-----
> > postgis-users mailing list
> > postgis-users at postgis.refractions.net
> > http://postgis.refractions.net/mailman/listinfo/postgis-users
Desc: Digital signature
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20080404/91b781c0/attachment.pgp>
