[postgis-users] Reprojecting a postgis layer
Jeremy Brenner
jeremyjbrenner at gmail.com
Fri Apr 4 17:06:00 PDT 2008
select ST_Transform( the_geom, 26911) from california_counties;
If you want it to be readable, you will need to convert it to text:
select ST_AsText( ST_Transform( the_geom, 26911 ) ) from california_counties;
Hope this helps.
On Fri, Apr 4, 2008 at 6:57 PM, Marcus C. England
<marcuscengland at gmail.com> wrote:
> Hi all,
> I have spent the last three hours trying to find a plain-English
> description of how you change the projection of a PostGIS layer, and I am
> now giving up. I have found quite a few questions about this on the
> internet, but not a single answer that allows for a newbie to SQL. Every
> answers states something like "transform (arguments)"... what arguments?
> So, here it goes. I have a layer called "california_counties". The layer's
> current SRID is correctly set at 3309. I want to transform the layer into
> SRID 26911. How do I do that? It seems it should be so simple.
> Thanks in advance for your help.
> -Marcus
> postgis-users mailing list
Jeremy Brenner
Phone: 618-219-2310
Email: jeremyjbrenner at gmail.com
