[postgis-users] Turn a Polygon into Lines
Drew Sheedy
drew at olvec.net
Sun Apr 6 16:53:22 PDT 2008
In the informix world you would cast the polygon to a geometry and then into
the line
ie:
select shape::st_geometry::st_multilinestring from bleargh
But have been able to cast the geometry type in postgis :(
On Mon, Apr 7, 2008 at 1:47 AM, Randall, Eric <ERandall at eriecountygov.org>
wrote:
> Lee Hachadoorian wrote:
> >* I'm looking through the PostGIS reference, and I can't seem to find a
> *>* way to take a geometry of polygons and turn it into lines. What I'm
> *>* looking for is something like the ArcGIS Feature to Line geoprocessor,
> *>* which will create a line shapefile where each feature is an arc
> *>* representing the boundary between neighboring polygons with a field
> *>* indicating the ids of the polygon on either side.
> *>* Functions like ST_MakeLine require point geometries, and I don't see
> *>* anything else that seems to be what I'm looking for. Any ideas would
> *>* be welcome.
> *>* Thanks,
> *>* Lee Hachadoorian
> *>* PhD Student in Geography
> *>* Program in Earth & Environmental Sciences
> *>* CUNY Graduate Center
> This is a correction to my March 31 post. I should have have tested a
> little more and not been in such a hurry I guess.
> I neglected to account for the cases where a non-shared edge needs to end
> at the beginning. Adding a case statement
> seems to have handled that. I'd like to find a way to reference the
> derived table (p4) multiple times to avoid
> repeating the query (p5). The Common Table Expression WITH statement
> should do this I think but it doesn't seem to be
> supported in my version of PostgreSQL (8.2). Can anyone give me some
> ideas? Thanks.
> -Eric
> example_turn_poly_into_lines.sql
> replace "polytable" with your poly table.
> replace gid value (309) with your poly's gid.
> select p4.poly_id,p4.adjacent_poly_id,p4.pos_order,p4.geom
> from
> /* Get edges shared with other polys */
> select t1.gid as poly_id,t2.gid as adjacent_poly_id,
> ST_line_locate_point(ST_linemerge(ST_boundary(t1.geom)),ST_startpoint(ST_linemerge(ST_intersection(ST_boundary(t1.geom),ST_boundary(t2.geom)))))
> as pos_order,
> ST_linemerge(ST_intersection(ST_linemerge(ST_boundary(t1.geom)),ST_linemerge(ST_boundary(t2.geom))))
> as geom
> from polytable t1, polytable t2
> where t1.gid = 309
> and ST_touches(t1.geom, t2.geom)
> union
> Create edges not shared with other polys. Uses -1 for pseudo external
> universe polygon.
> Produces extra line(s) where there is more than one non-shared edge,
> necessitating the self-join and ST_covers filter at the end.
> Need help, more work on this, ...suggestions?
> select p1.poly_id, p1.adjacent_poly_id, p1.position as
> pos_order,ST_line_substring(p3.geom,p1.position,p2.position) as geom
> from
> select t1.gid as poly_id,-1::integer as adjacent_poly_id,
> ST_line_locate_point(ST_linemerge(ST_boundary(t1.geom)),ST_endpoint(ST_linemerge(ST_intersection(ST_boundary(t1.geom),ST_boundary(t2.geom)))))
> as position,
> as geom
> where t1.gid = 309
> and
> not in
> select
> as geom
> where t1.gid = 309
> as p1,
> case
> when 0 then 1
> else
> ST_line_locate_point(ST_linemerge(boundary(t1.geom)),ST_startpoint(ST_linemerge(ST_intersection(ST_boundary(t1.geom),ST_boundary(t2.geom)))))
> end
> as position,
> as geom
> where t1.gid = 309
> and
> not in
> select
> as geom
> where t1.gid = 309
> as p2,
> select ST_linemerge(ST_boundary(geom)) as geom
> from polytable
> where gid = 309
> as p3
> where p1.position < p2.position
> as p4,
> /* repeat for needed self join */
> as pos_order,
> as geom
> where t1.gid = 309
> union
> universe polygon.
> select p1.poly_id, p1.adjacent_poly_id, p1.position as pos_order,
> from
> as position,
> as geom
> where t1.gid = 309
> and
> not in
> select
> as geom
> where t1.gid = 309
> as p1,
> case
> when 0 then 1
> else
> end
> as position,
> as geom
> where t1.gid = 309
> and
> not in
> select
> as geom
> where t1.gid = 309
> as p2,
> from polytable
> where gid = 309
> as p3
> as p5
> where ST_covers(p4.geom,p5.geom)
> group by p4.poly_id,p4.adjacent_poly_id,p4.pos_order,p4.geom
> having count(ST_covers(p4.geom,p5.geom)) = 1
> order by p4.pos_order
> Eric Randall
> County of Erie
> 140 W 6th St
> Room 119
> Erie, PA 16501
> ph. 814-451-6063
> fx. 814-451-7000
> postgis-users mailing list
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20080407/b4d0ec66/attachment.html>
