[postgis-users] postgis mapfile php
Stephen Woodbridge
woodbri at swoodbridge.com
Sun Apr 6 18:31:59 PDT 2008
>> i have map who takes the data from a database
>> in the database there is a column "name"
>> my data are be shown with
>> LAYER
>> NAME "country"
>> TYPE POLYGON
>> STATUS ON
>> CONNECTIONTYPE postgis
>> CONNECTION "host=localhost dbname=postgis user=postgres
>> password=d3klw7 port=5432"
>> DATA "the_geom from europe_country using unique gid using
>> srid=-1"
>> LABELITEM "name"
>> what i wanna is.. i have a menu who takes all the countries from the
>> column name...
>> if i select a country
>> eg.greece
>> how i could change the statement in the mapfile
>> DATA "the_geom from europe_country using unique gid using srid=-1"
>> with the statement
>> DATA "the_geom from europe_country where name=greece using unique gid
>> using srid=-1" so to be shown only greece??? pls help me..i need to finish
>> my diploma with taht
>> eg..i knnow if we wanna to change the status of a layer we use that
>> $this_layer = $map->getLayerByName('europe cities');
>> $this_layer->set('status', MS_ON);
>> sth similar like the above to change the statement of data?
> also.. i wanna know sth else.. in the mapfile ..i have in data
> if i changed it in DATA "the_geom from europe_country where name="Greece"
> it should be shown greece ?? right?
> but nothing is shown ..it gives me error ...knows anyone what is wrong?
Try something like:
DATA "the_geom from ( select gid, the_geom from europe_country where
name='Greece') as foo
