[postgis-users] Turn a Polygon into Lines
Randall, Eric ERandall at eriecountygov.org
Mon Apr 7 06:37:24 PDT 2008
Drew,
"select st_multi(st_linemerge(st_boundary(shape))) from bleargh"
would be the PostGIS equivalent to your informix statement I believe, however that is not what I am trying to do (see Lee's first paragraph below).  I don't use Informix but I would certainly be interested in seeing an Informix solution, or DB2, Oracle, or SQL Server 2008 for that matter.  Not being PostGIS related though, you should probably send it to me off the list or post it to an informix spatial list, etc.  Thanks.
-Eric
Drew Sheedy wrote:
>> In the informix world you would cast the polygon to a geometry and then into
>> the line
>> ie:
>> select shape::st_geometry::st_multilinestring from bleargh
>> But have been able to cast the geometry type in postgis :(
On Mon, Apr 7, 2008 at 1:47 AM, Randall, Eric <ERandall at eriecountygov.org>
wrote:
> Lee Hachadoorian wrote:
> >* I'm looking through the PostGIS reference, and I can't seem to find a
> *>* way to take a geometry of polygons and turn it into lines.  What I'm
> *>* looking for is something like the ArcGIS Feature to Line geoprocessor,
> *>* which will create a line shapefile where each feature is an arc
> *>* representing the boundary between neighboring polygons with a field
> *>* indicating the ids of the polygon on either side.
> *>* Functions like ST_MakeLine require point geometries, and I don't see
> *>* anything else that seems to be what I'm looking for.  Any ideas would
> *>* be welcome.
> *>* Thanks,
> *>* Lee Hachadoorian
> *>* PhD Student in Geography
> *>* Program in Earth & Environmental Sciences
> *>* CUNY Graduate Center
> This is a correction to my March 31 post.   I should have have tested a
> little more and not been in such a hurry I guess.
> I neglected to account for the cases where a non-shared edge needs to end
> at the beginning.  Adding a case statement
> seems to have handled that.   I'd like to find a way to reference the
> derived table (p4) multiple times to avoid
> repeating the query  (p5).  The Common Table Expression WITH statement
> should do this I think but it doesn't seem to be
> supported in my version of PostgreSQL (8.2).  Can anyone give me some
> ideas?  Thanks.
> -Eric
>     example_turn_poly_into_lines.sql
>    replace "polytable" with your poly table.
>    replace gid value (309) with your poly's gid.
> select p4.poly_id,p4.adjacent_poly_id,p4.pos_order,p4.geom
> from
> /* Get edges shared with other polys */
> select t1.gid as poly_id,t2.gid as adjacent_poly_id,
> ST_line_locate_point(ST_linemerge(ST_boundary(t1.geom)),ST_startpoint(ST_linemerge(ST_intersection(ST_boundary(t1.geom),ST_boundary(t2.geom)))))
> as pos_order,
> ST_linemerge(ST_intersection(ST_linemerge(ST_boundary(t1.geom)),ST_linemerge(ST_boundary(t2.geom))))
> as geom
> from polytable t1, polytable t2
> where t1.gid = 309
> and ST_touches(t1.geom, t2.geom)
> union
>    Create edges not shared with other polys.  Uses -1 for pseudo external
> universe polygon.
>    Produces extra line(s) where there is more than one non-shared edge,
>    necessitating the self-join and ST_covers filter at the end.
>    Need help, more work on this, ...suggestions?
> select p1.poly_id, p1.adjacent_poly_id, p1.position as
> pos_order,ST_line_substring(p3.geom,p1.position,p2.position)  as geom
> from
> select t1.gid as poly_id,-1::integer as adjacent_poly_id,
> ST_line_locate_point(ST_linemerge(ST_boundary(t1.geom)),ST_endpoint(ST_linemerge(ST_intersection(ST_boundary(t1.geom),ST_boundary(t2.geom)))))
> as position,
> as geom
> where t1.gid = 309
> and
> not in
> select
> as geom
> where t1.gid = 309
> as p1,
> case
> when 0 then 1
> else
> ST_line_locate_point(ST_linemerge(boundary(t1.geom)),ST_startpoint(ST_linemerge(ST_intersection(ST_boundary(t1.geom),ST_boundary(t2.geom)))))
> end
> as position,
> as geom
> where t1.gid = 309
> and
> not in
> select
> as geom
> where t1.gid = 309
> as p2,
> select ST_linemerge(ST_boundary(geom)) as geom
> from polytable
> where gid = 309
> as p3
> where p1.position < p2.position
> as p4,
> /* repeat for needed self join */
> as pos_order,
> as geom
> where t1.gid = 309
> union
> universe polygon.
> select p1.poly_id, p1.adjacent_poly_id, p1.position as pos_order,
> from
> as position,
> as geom
> where t1.gid = 309
> and
> not in
> select
> as geom
> where t1.gid = 309
> as p1,
> case
> when 0 then 1
> else
> end
> as position,
> as geom
> where t1.gid = 309
> and
> not in
> select
> as geom
> where t1.gid = 309
> as p2,
> from polytable
> where gid = 309
> as p3
> as p5
> where ST_covers(p4.geom,p5.geom)
> group by p4.poly_id,p4.adjacent_poly_id,p4.pos_order,p4.geom
> having count(ST_covers(p4.geom,p5.geom)) = 1
> order by p4.pos_order
> Eric Randall
> County of Erie
> 140 W 6th St
> Room 119
> Erie, PA 16501
> ph. 814-451-6063
> fx. 814-451-7000
