[postgis-users] postgis mapfile php
nickthegreek-
nickthegreek_ at hotmail.com
Mon Apr 7 16:39:00 PDT 2008
<select namex="mydropdown">
<?php
for ($lt = 0; $lt < pg_numrows($myresult); $lt++) {
$id = pg_result($myresult, $lt, 0);
<option value="name"> <?php echo $id;?> </option>
<?php
</select>
<input type="checkbox" name="layer[]"
value="countries" <?php echo $countries;?> >
i have this select whick takes the results from a column from a database...
i haven;t put this select in a form cause it will be inside an othe form ..
but i think it works perfect as it nows...
how can i take the selected value from the menu? which is ? $namex?
$mydropdown??
and how can i put it here.. like ..
the_geom from ( select gid, the_geom from europe_country where
name='$namex') as foo using unique gid using srid=-1
View this message in context: http://www.nabble.com/postgis-mapfile-php-tp16530438p16543003.html
Sent from the PostGIS - User mailing list archive at Nabble.com.
