[postgis-users] Best graphical viewer for PostGIS data
Aigars V aigarsv at gmail.com
Wed Apr 9 06:06:04 PDT 2008
http://www.spatialserver.net/osgis/
2008/4/8, Kevin Neufeld <kneufeld at refractions.net>:
> I prefer OpenJump as well.  Through plugins I wrote myself, I can view or
> edit data directly in PostGIS pulled either from a single table or any SQL
> query that returns a single geometry column.  Since the database I often
> work with is ~150GB I need to be able to load data into Jump dynamically,
> that is, only load data whose bounding box intersects the current viewport.
>  (Though the plugin can also ignore the bounding box filter and statically
> load the entire content of any SQL query or table entirely in memory).
> I don't know the state of any publicly available plugins that permit
> dynamic data editing, but OpenJump does come with a limited dynamic viewer
> plugin that permits the viewing of a single table (optionally with filters
> applied).
> Cheers,
> Kevin
> Randall, Eric wrote:
> > I use OpenJump the most because of the dbquery plugin.  Immediate
> > viewing of any query that returns a geometry, derived or otherwise, is the
> > most important feature for me.  I use it as sort of a tester/designer for
> > automating recurring tasks that have a spatial analytical component.  All
> > editing is done in other software, outside of postgres/postgis, and reloaded
> > monthly.
> > -----Original Message-----
> > From: postgis-users-bounces at postgis.refractions.net
> > [mailto:postgis-users-bounces at postgis.refractions.net]On Behalf Of
> > Pierre Racine
> > Sent: Tuesday, April 08, 2008 11:22 AM
> > To: postgis-users at postgis.refractions.net
> > Subject: [postgis-users] Best graphical viewer for PostGIS data
> > Hi,
> > I would like to hear from you guys about the viewer you use to "see"
> > PostGIS geometries. Which one is the best and why? How do they support
> > views, editing, creation, etc...
> > I can list a couple of them:
> > QGIS
> > uDIG
> > GRASS
> > MapServer
> > Any others?
> > Pierre
> > postgis-users mailing list
> > http://postgis.refractions.net/mailman/listinfo/postgis-users
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20080409/a50459f5/attachment.html>
