[postgis-users] Best graphical viewer for PostGIS data
Michaël Michaud
michael.michaud at free.fr
Wed Apr 9 11:32:39 PDT 2008
I cannot say I tried many viewers with postgis, but I'm quite satisfied
with OpenJUMP, and I can say this one is not only a viewer ;-).
I use it to access a huge database (more than 50 millions objects ). Of
course, OpenJUMP can't load the whole database into memory, but I wrote
some plugins to easily extract the data I need (using the fence to do
geometric extraction and prepared xml profiles as semantic filters)
Michaël
Aigars V a écrit :
> http://www.spatialserver.net/osgis/
> 2008/4/8, Kevin Neufeld <kneufeld at refractions.net
> <mailto:kneufeld at refractions.net>>:
> I prefer OpenJump as well. Through plugins I wrote myself, I can
> view or edit data directly in PostGIS pulled either from a single
> table or any SQL query that returns a single geometry column.
> Since the database I often work with is ~150GB I need to be able
> to load data into Jump dynamically, that is, only load data whose
> bounding box intersects the current viewport. (Though the plugin
> can also ignore the bounding box filter and statically load the
> entire content of any SQL query or table entirely in memory).
> I don't know the state of any publicly available plugins that
> permit dynamic data editing, but OpenJump does come with a limited
> dynamic viewer plugin that permits the viewing of a single table
> (optionally with filters applied).
> Cheers,
> Kevin
> Randall, Eric wrote:
> I use OpenJump the most because of the dbquery plugin.
> Immediate viewing of any query that returns a geometry,
> derived or otherwise, is the most important feature for me. I
> use it as sort of a tester/designer for automating recurring
> tasks that have a spatial analytical component. All editing
> is done in other software, outside of postgres/postgis, and
> reloaded monthly.
> -----Original Message-----
> From: postgis-users-bounces at postgis.refractions.net
> <mailto:postgis-users-bounces at postgis.refractions.net>
> [mailto:postgis-users-bounces at postgis.refractions.net
> <mailto:postgis-users-bounces at postgis.refractions.net>]On
> Behalf Of
> Pierre Racine
> Sent: Tuesday, April 08, 2008 11:22 AM
> To: postgis-users at postgis.refractions.net
> <mailto:postgis-users at postgis.refractions.net>
> Subject: [postgis-users] Best graphical viewer for PostGIS data
> Hi,
> I would like to hear from you guys about the viewer you use to
> "see"
> PostGIS geometries. Which one is the best and why? How do they
> support
> views, editing, creation, etc...
> I can list a couple of them:
> QGIS
> uDIG
> GRASS
> MapServer
> Any others?
> Pierre
> postgis-users mailing list
>_______________________________________________
