[postgis-users] Best graphical viewer for PostGIS data
Sinboy Zhang
iamsinboy at gmail.com
Wed Apr 9 23:42:06 PDT 2008
I tried to use openJUMP,but could not start it sucessfully with the errors:
Should never reach here(Assertion failed exception)
why?
My Environment:Win XP,JDK1.5
2008/4/10, Michaël Michaud <michael.michaud at free.fr>:
> I cannot say I tried many viewers with postgis, but I'm quite satisfied
> with OpenJUMP, and I can say this one is not only a viewer ;-).
> I use it to access a huge database (more than 50 millions objects ). Of
> course, OpenJUMP can't load the whole database into memory, but I wrote some
> plugins to easily extract the data I need (using the fence to do geometric
> extraction and prepared xml profiles as semantic filters)
> Michaël
> Aigars V a écrit :
> > http://www.spatialserver.net/osgis/
> > 2008/4/8, Kevin Neufeld <kneufeld at refractions.net <mailto:
> > kneufeld at refractions.net>>:
> > I prefer OpenJump as well. Through plugins I wrote myself, I can
> > view or edit data directly in PostGIS pulled either from a single
> > table or any SQL query that returns a single geometry column.
> > Since the database I often work with is ~150GB I need to be able
> > to load data into Jump dynamically, that is, only load data whose
> > bounding box intersects the current viewport. (Though the plugin
> > can also ignore the bounding box filter and statically load the
> > entire content of any SQL query or table entirely in memory).
> > I don't know the state of any publicly available plugins that
> > permit dynamic data editing, but OpenJump does come with a limited
> > dynamic viewer plugin that permits the viewing of a single table
> > (optionally with filters applied).
> > Cheers,
> > Kevin
> > Randall, Eric wrote:
> > I use OpenJump the most because of the dbquery plugin.
> > Immediate viewing of any query that returns a geometry,
> > derived or otherwise, is the most important feature for me. I
> > use it as sort of a tester/designer for automating recurring
> > tasks that have a spatial analytical component. All editing
> > is done in other software, outside of postgres/postgis, and
> > reloaded monthly.
> > -----Original Message-----
> > From: postgis-users-bounces at postgis.refractions.net
> > <mailto:postgis-users-bounces at postgis.refractions.net>
> > [mailto:postgis-users-bounces at postgis.refractions.net
> > <mailto:postgis-users-bounces at postgis.refractions.net>]On
> > Behalf Of
> > Pierre Racine
> > Sent: Tuesday, April 08, 2008 11:22 AM
> > To: postgis-users at postgis.refractions.net
> > <mailto:postgis-users at postgis.refractions.net>
> > Subject: [postgis-users] Best graphical viewer for PostGIS data
> > Hi,
> > I would like to hear from you guys about the viewer you use to
> > "see"
> > PostGIS geometries. Which one is the best and why? How do they
> > support
> > views, editing, creation, etc...
> > I can list a couple of them:
> > QGIS
> > uDIG
> > GRASS
> > MapServer
> > Any others?
> > Pierre
> > postgis-users mailing list
> > http://postgis.refractions.net/mailman/listinfo/postgis-users
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20080410/ac3ef3eb/attachment.html>
