[postgis-users] 1.3.3 Pre-Release Notice
Paul Ramsey
pramsey at cleverelephant.ca
Wed Apr 9 09:10:34 PDT 2008
Regina,
Actually this logic is good, very old and hasn't worked since it was
written, but good. Because if I ever want to change the value of "no
SRID" from -1 to 0 (and I *do* want to) then having "undefined"
generated as truly undefined is helpful to that end.
P.
On Wed, Apr 9, 2008 at 9:02 AM, Obe, Regina <robe.dnd at cityofboston.gov> wrote:
> This may be a dumb question, but why can't we just skip the strcmp
> altogether?
> I mean if you do
> if (sr_id)
> and someone did happen to explicity set their sr_id = "-1"
> then what happens
> "SRID=-1;"
> Isn't that still legal and gets kicked out by Postgis anyway.
> Thanks,
> Regina
> -----Original Message-----
> From: postgis-users-bounces at postgis.refractions.net
> [mailto:postgis-users-bounces at postgis.refractions.net] On Behalf Of Paul
> Ramsey
> Sent: Wednesday, April 09, 2008 11:23 AM
> To: PostGIS Users Discussion
> Subject: Re: [postgis-users] 1.3.3 Pre-Release Notice
> > if ( sr_id && strcmp(sr_id,"-1") ) printf("SRID=%s;", sr_id);
> > I have a very strong feeling that evaluation order in C is
> unspecified, rather
> > than being from left to right; so for example the compiler could
> decide to
> > generate code that evaluates the strcmp() first, in which case it
> would
> > segfault on a NULL :( I think you would need to re-write something
> like this:
> Should be fine: man -S7 operator
> > if (sr_id)
> > if (strcmp(sr_id,"-1") ) printf("SRID=%s;", sr_id);
> > (looks even closer...)
> > In fact, why is sr_id stored as a string anyway? We should make sr_id
> an
> > integer with a default value of -1, and then use sscanf() within the
> switch()
> > statement of pgis_getopt() to read its value.
> I'll have a look at that, how is the estimated_extent investigation
> coming?
> postgis-users mailing list
> The substance of this message, including any attachments, may be
> confidential, legally privileged and/or exempt from disclosure
> pursuant to Massachusetts law. It is intended
> solely for the addressee. If you received this in error, please
> contact the sender and delete the material from any computer.
