[postgis-users] 1.3.3 Pre-Release Notice
Obe, Regina robe.dnd at cityofboston.gov
Wed Apr 9 12:01:53 PDT 2008
I don't know - I would think if you did change no SRID to 0, then instead of ignoring -1, we should have it blow up in people's faces at the PostGIS layer if they explicitly try to set it to that with a "This is not a valid SRID rather than casting to unknown" . That will get them used to the new convention.
Perhaps its a bit militant, but its better than some strange -1 check dangling in the code (and risking a potential segfault that Mark mentioned).  You don't want  people wondering down the road who are used to 0 seeing -1 and scratching their heads - "What is this -1 doing here?  Why aren't we ignoring all negative SRIDs".
R.
From: postgis-users-bounces at postgis.refractions.net on behalf of Paul Ramsey
Sent: Wed 4/9/2008 12:10 PM
To: PostGIS Users Discussion
Subject: Re: [postgis-users] 1.3.3 Pre-Release Notice
Regina,
Actually this logic is good, very old and hasn't worked since it was
written, but good.  Because if I ever want to change the value of "no
SRID" from -1 to 0 (and I *do* want to) then having "undefined"
generated as truly undefined is helpful to that end.
P.
On Wed, Apr 9, 2008 at 9:02 AM, Obe, Regina <robe.dnd at cityofboston.gov> wrote:
> This may be a dumb question, but why can't we just skip the strcmp
>  altogether?
>  I mean if you do
>  if (sr_id)
>  and someone did happen to explicity set their sr_id = "-1"
>  then  what happens
>  "SRID=-1;"
>  Isn't that still legal and gets kicked out by Postgis anyway.
>  Thanks,
>  Regina
>  -----Original Message-----
>  [mailto:postgis-users-bounces at postgis.refractions.net] On Behalf Of Paul
>  Ramsey
> Sent: Wednesday, April 09, 2008 11:23 AM
> >  if ( sr_id && strcmp(sr_id,"-1") ) printf("SRID=%s;", sr_id);
>  >  I have a very strong feeling that evaluation order in C is
>  unspecified, rather
>  >  than being from left to right; so for example the compiler could
>  decide to
>  >  generate code that evaluates the strcmp() first, in which case it
>  would
>  >  segfault on a NULL :( I think you would need to re-write something
>  like this:
>  Should be fine: man -S7 operator
>  >  if (sr_id)
>  >         if (strcmp(sr_id,"-1") ) printf("SRID=%s;", sr_id);
>  >  (looks even closer...)
>  >  In fact, why is sr_id stored as a string anyway? We should make sr_id
>  an
>  >  integer with a default value of -1, and then use sscanf() within the
>  switch()
>  >  statement of pgis_getopt() to read its value.
>  I'll have a look at that, how is the estimated_extent investigation
>  coming?
>  postgis-users mailing list
>  postgis-users at postgis.refractions.net
>  http://postgis.refractions.net/mailman/listinfo/postgis-users
>  The substance of this message, including any attachments, may be
>  confidential, legally privileged and/or exempt from disclosure
>  pursuant to Massachusetts law. It is intended
>  solely for the addressee. If you received this in error, please
>  contact the sender and delete the material from any computer.
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20080409/2a513008/attachment.html>
