[postgis-users] Size of FTDate field in dbf files
Peter Hopfgartner peter.hopfgartner at r3-gis.com
Thu Apr 10 03:29:13 PDT 2008
Dear PostGIS developers
After having changed the field size from 10 to 8 everything works fine
as expected.
This means that the comment in file pgsql2shp.c, lines 2730,2731 is not
accurate anymore.
The attached diff is against the current SVN.
Best regards,
Peter Hopfgartner and Sergio Segala
R3 GIS
http://www.r3-gis.com
Peter Hopfgartner wrote:
> Dear mailing list members,
> we had some problems when editing shape files containing dates
> generated with pgsql2shp. In particular, editing these files with
> ArcGIS and some OS desptop GIS (QGIS or OpenJump, sorry I can't
> remember exactly) the attributes where shifted by some white spaces.
> Looking at the files generated with pgsql2shp, we noted that  a length
> of 10 bytes is assigned to date fields (see also current the svn
> snapshot, loader/pgsql2shp.c:2735,2736), in apparent contrast with the
> dbf file format specification
> (http://www.dbase.com/knowledgebase/int/db7_file_fmt.htm), which
> specifies that these field are 8 bytes long.
> Best regards,
> R3 GIS
> postgis-users mailing list
Type: text/x-patch
Desc: not available
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20080410/cc9bce4a/attachment.bin>
