[postgis-users] shp2pgsql: not accepting the command?
Stefan Schwarzer stefan.schwarzer at grid.unep.ch
Thu Apr 10 05:23:53 PDT 2008
sorry for coming back to this issue... (and for sending a similar mail
just a couple of minutes ago before I realized that this subject
already was discussed - but not solved...)
Is there any chance that this subject (for 10.5) has been solved? Any
suggestions? I used the macports to install postgres (8.2) and postgis
(1.3.1)...
Thanks for any suggestions. It's weeks now that I try to get the stuff
running, with lots of (re)installations.... but in vain...
Stef
On Mar 5, 2008, at 4:08 PM, William Kyngesburye wrote:
> Stefan, you're using my PostGIS binary?  I thought I had renamed the
> Postgis getopt() to force it to be the one used, but looking at my
> source I see that I didn't, this time.  I must have downloaded a
> fresh copy of the source and forgot that patch.
> And, do you have a 64bit Mac (Core 2 Duo) or one of the first 32bit
> Core Duo Macs?
> Mark, I don't know about the original why, but in this case, the
> PostGIS getopt() works, while the OSX 10.5 32bit getopt() does not.
> The 64bit OSX getopt() does work.  There has been a system update
> since then, so I need to test it again.  (actually, very soon, since
> I was just about to rebuild for Postgres 8.3)
> On Mar 5, 2008, at 4:55 AM, Mark Cave-Ayland wrote:
>> On Wednesday 05 March 2008 05:51:12 Stefan Schwarzer wrote:
>>> Ah... yes indeed. 10.5.
>>> So, what do you recommend? Wait and see? Hmm....
>> I think the first question to ask is why do we supply our own copy
>> of getopt
>> with shp2pgsql/pgsql in the first place? Is it because it's missing
>> on
>> something like Solaris? My temptation would be to simply remove it,
>> and let
>> everything use the system getopt...
>> Kind regards,
>> Mark.
> William Kyngesburye <kyngchaos*at*kyngchaos*dot*com>
> http://www.kyngchaos.com/
> "This is a question about the past, is it? ... How can I tell that
> the past isn't a fiction designed to account for the discrepancy
> between my immediate physical sensations and my state of mind?"
> - The Ruler of the Universe
