[postgis-users] Proper Installation of Postgres and Postgis on 10.5 Intel
Stefan Schwarzer
stefan.schwarzer at grid.unep.ch
Thu Apr 10 13:23:18 PDT 2008
Cheers William,
thanks for your engagement!
I sent you an email a couple of days ago, which showed the same
problems as we had before. Generally, I would say that it always comes
down to the same thing: The postgres server craches when importing/
restoring dumped tables with geometries.
It just comes to my mind, that, perhaps, it's not a problem of
postgres/postgis installation, but a problem of the tables within the
(old) database, which i try to import?! I should try (tomorrow) to
import a couple of "known" shapefiles, as the ones delivered with the
ESRI stuff for example...
Thanks for your input guys, I will try, with new motivation, to get my
beast running tomorrow morning...
Stef
> Hi Stefan,
> Last time we talked you were having problems with the confusion of
> the postgres system user and postgres role and the automatic startup
> of postgres.
> I'd like to get it working for you, so don't give up yet.
> On Apr 10, 2008, at 9:21 AM, Stefan Schwarzer wrote:
>>> Is there any chance that this subject (for 10.5) has been solved?
>>> Any suggestions? I used the macports to install postgres (8.2) and
>>> postgis (1.3.1)...
>> I would, after all the experiences I went through, ask the question
>> slightly different... :
>> Can anybody give me installation instructions on how to install
>> postgres & postgis on Leopard (with a MacPro)? Either by hand-
>> compiling or with MacPorts? Or some other stuff? Strange enough,
>> even the kyngchaos libs didn't work, even after having completely
>> re-installed my machine...
>> Thanks thousand times for any such advice!
>> Stef
>> postgis-users mailing list
>> postgis-users at postgis.refractions.net
>> http://postgis.refractions.net/mailman/listinfo/postgis-users
> William Kyngesburye <kyngchaos*at*kyngchaos*dot*com>
> http://www.kyngchaos.com/
> "Those people who most want to rule people are, ipso-facto, those
> least suited to do it."
> - A rule of the universe, from the HitchHiker's Guide to the Galaxy
