[postgis-users] Best graphical viewer for PostGIS data
Sinboy Zhang
iamsinboy at gmail.com
Thu Apr 10 23:40:53 PDT 2008
*Hardware*
CPU:AMD Sempron Processor 2600+ Socket 754 1.6GHz
Memory:512M DDR
Hard Disk: WDC WD800BB-88JHCO 80G
Mainboard:K8M800-M3 CMOS:VIA BIOS:Phoenix
*Software:*
Windows XP Professional SP2
JDK 1.5.0_04
openJUMP -1.2 for win32
*Error:*
com.vividsolutions.jts.util.AssertionFailedException: Should never reach
here
at com.vividsolutions.jts.util.Assert.shouldNeverReachHere(Assert.java:122)
at com.vividsolutions.jts.util.Assert.shouldNeverReachHere(Assert.java:111)
at
com.vividsolutions.jump.workbench.ui.plugin.FeatureInstaller.abstractPlugInActionListener(FeatureInstaller.java:553)
at
com.vividsolutions.jump.workbench.ui.plugin.FeatureInstaller.addMainMenuItemWithJava14Fix(FeatureInstaller.java:532)
at
com.vividsolutions.jump.workbench.JUMPConfiguration.configureMainMenus(JUMPConfiguration.java:753)
at
com.vividsolutions.jump.workbench.JUMPConfiguration.setup(JUMPConfiguration.java:373)
at
com.vividsolutions.jump.workbench.JUMPWorkbench.main(JUMPWorkbench.java:259)
at
com.vividsolutions.jump.workbench.JUMPWorkbench.main(JUMPWorkbench.java:224)
2008/4/10, Michaël Michaud <michael.michaud at free.fr>:
> Hi Sinboy,
> I answer with a copy to the OpenJUMP discussion list where you will find
> more help.
> Can you please give to this list more details about which version of
> OpenJUMP you did try and what is the complete error message you get.
> Michaël
> Sinboy Zhang a écrit :
> I tried to use openJUMP,but could not start it sucessfully with the
> > errors:
> > Should never reach here(Assertion failed exception)
> > why?
> > My Environment:Win XP,JDK1.5
> > 2008/4/10, Michaël Michaud <michael.michaud at free.fr <mailto:
> > michael.michaud at free.fr>>:
> > I cannot say I tried many viewers with postgis, but I'm quite
> > satisfied with OpenJUMP, and I can say this one is not only a
> > viewer ;-).
> > I use it to access a huge database (more than 50 millions objects
> > ). Of course, OpenJUMP can't load the whole database into memory,
> > but I wrote some plugins to easily extract the data I need (using
> > the fence to do geometric extraction and prepared xml profiles as
> > semantic filters)
> > Michaël
> > Aigars V a écrit :
> > http://www.spatialserver.net/osgis/
> > 2008/4/8, Kevin Neufeld <kneufeld at refractions.net
> > <mailto:kneufeld at refractions.net>
> > <mailto:kneufeld at refractions.net>>>:
> > I prefer OpenJump as well. Through plugins I wrote myself,
> > I can
> > view or edit data directly in PostGIS pulled either from a
> > single
> > table or any SQL query that returns a single geometry column.
> > Since the database I often work with is ~150GB I need to
> > be able
> > to load data into Jump dynamically, that is, only load data
> > whose
> > bounding box intersects the current viewport. (Though the
> > plugin
> > can also ignore the bounding box filter and statically load
> > the
> > entire content of any SQL query or table entirely in memory).
> > I don't know the state of any publicly available plugins that
> > permit dynamic data editing, but OpenJump does come with a
> > limited
> > dynamic viewer plugin that permits the viewing of a single
> > table
> > (optionally with filters applied).
> > Cheers,
> > Kevin
> > Randall, Eric wrote:
> > I use OpenJump the most because of the dbquery plugin.
> > Immediate viewing of any query that returns a geometry,
> > derived or otherwise, is the most important feature for
> > me. I
> > use it as sort of a tester/designer for automating
> > recurring
> > tasks that have a spatial analytical component. All
> > editing
> > is done in other software, outside of postgres/postgis,
> > and
> > reloaded monthly.
> > -----Original Message-----
> > From: postgis-users-bounces at postgis.refractions.net
> > <mailto:postgis-users-bounces at postgis.refractions.net>
> > <mailto:postgis-users-bounces at postgis.refractions.net>>
> > [mailto:postgis-users-bounces at postgis.refractions.net
> > <mailto:postgis-users-bounces at postgis.refractions.net>>]On
> > Behalf Of
> > Pierre Racine
> > Sent: Tuesday, April 08, 2008 11:22 AM
> > To: postgis-users at postgis.refractions.net
> > <mailto:postgis-users at postgis.refractions.net>
> > <mailto:postgis-users at postgis.refractions.net>>
> > Subject: [postgis-users] Best graphical viewer for
> > PostGIS data
> > Hi,
> > I would like to hear from you guys about the viewer you
> > use to
> > "see"
> > PostGIS geometries. Which one is the best and why? How
> > do they
> > support
> > views, editing, creation, etc...
> > I can list a couple of them:
> > QGIS
> > uDIG
> > GRASS
> > MapServer
> > Any others?
> > Pierre
> > postgis-users mailing list
> > http://postgis.refractions.net/mailman/listinfo/postgis-users
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20080411/e0a1a2d2/attachment.html>
