[postgis-users] Best graphical viewer for PostGIS data
Martin Chapman mchapman at texelinc.com
Thu Apr 10 23:55:38 PDT 2008
Maybe try:
http://www.viewportimaging.com
Best regards,
Martin
From: postgis-users-bounces at postgis.refractions.net [mailto:postgis-users-bounces at postgis.refractions.net] On Behalf Of Sinboy Zhang
Sent: Friday, April 11, 2008 12:41 AM
To: PostGIS Users Discussion
Subject: Re: [postgis-users] Best graphical viewer for PostGIS data
Hardware
CPU:AMD Sempron Processor 2600+ Socket 754 1.6GHz
Memory:512M DDR
Hard Disk: WDC WD800BB-88JHCO 80G
Mainboard:K8M800-M3 CMOS:VIA BIOS:Phoenix
Software:
Windows XP Professional SP2
JDK 1.5.0_04
openJUMP -1.2 for win32
Error:
com.vividsolutions.jts.util.AssertionFailedException: Should never reach here
 at com.vividsolutions.jts.util.Assert.shouldNeverReachHere(Assert.java:122)
 at com.vividsolutions.jts.util.Assert.shouldNeverReachHere(Assert.java:111)
 at com.vividsolutions.jump.workbench.ui.plugin.FeatureInstaller.abstractPlugInActionListener(FeatureInstaller.java:553)
 at com.vividsolutions.jump.workbench.ui.plugin.FeatureInstaller.addMainMenuItemWithJava14Fix(FeatureInstaller.java:532)
 at com.vividsolutions.jump.workbench.JUMPConfiguration.configureMainMenus(JUMPConfiguration.java:753)
 at com.vividsolutions.jump.workbench.JUMPConfiguration.setup(JUMPConfiguration.java:373)
 at com.vividsolutions.jump.workbench.JUMPWorkbench.main(JUMPWorkbench.java:259)
 at com.vividsolutions.jump.workbench.JUMPWorkbench.main(JUMPWorkbench.java:224)
2008/4/10, Michaël Michaud <michael.michaud at free.fr>:
Hi Sinboy,
I answer with a copy to the OpenJUMP discussion list where you will find more help.
Can you please give to this list more details about which version of OpenJUMP you did try and what is the complete error message you get.
Michaël
Sinboy Zhang a écrit :
 I tried to use openJUMP,but could not start it sucessfully with the errors:
 Should never reach here(Assertion failed exception)
 why?
 My Environment:Win XP,JDK1.5
 2008/4/10, Michaël Michaud <michael.michaud at free.fr <mailto:michael.michaud at free.fr>>:
   I cannot say I tried many viewers with postgis, but I'm quite
   satisfied with OpenJUMP, and I can say this one is not only a
   viewer ;-).
   I use it to access a huge database (more than 50 millions objects
   ). Of course, OpenJUMP can't load the whole database into memory,
   but I wrote some plugins to easily extract the data I need (using
   the fence to do geometric extraction and prepared xml profiles as
   semantic filters)
   Michaël
   Aigars V a écrit :
       http://www.spatialserver.net/osgis/
       2008/4/8, Kevin Neufeld <kneufeld at refractions.net
       <mailto:kneufeld at refractions.net>
       <mailto:kneufeld at refractions.net>>>:
          I prefer OpenJump as well.  Through plugins I wrote myself,
       I can
          view or edit data directly in PostGIS pulled either from a
       single
          table or any SQL query that returns a single geometry column.
           Since the database I often work with is ~150GB I need to
       be able
          to load data into Jump dynamically, that is, only load data
       whose
          bounding box intersects the current viewport.  (Though the
       plugin
          can also ignore the bounding box filter and statically load the
          entire content of any SQL query or table entirely in memory).
          I don't know the state of any publicly available plugins that
          permit dynamic data editing, but OpenJump does come with a
       limited
          dynamic viewer plugin that permits the viewing of a single
       table
          (optionally with filters applied).
          Cheers,
          Kevin
          Randall, Eric wrote:
              I use OpenJump the most because of the dbquery plugin.
               Immediate viewing of any query that returns a geometry,
              derived or otherwise, is the most important feature for
       me.  I
              use it as sort of a tester/designer for automating
       recurring
              tasks that have a spatial analytical component.  All
       editing
              is done in other software, outside of postgres/postgis, and
              reloaded monthly.
              -----Original Message-----
       <mailto:postgis-users-bounces at postgis.refractions.net>
       <mailto:postgis-users-bounces at postgis.refractions.net>>
       <mailto:postgis-users-bounces at postgis.refractions.net>>]On
              Behalf Of
              Pierre Racine
              Sent: Tuesday, April 08, 2008 11:22 AM
              To: postgis-users at postgis.refractions.net
       <mailto:postgis-users at postgis.refractions.net>
       <mailto:postgis-users at postgis.refractions.net>>
              Subject: [postgis-users] Best graphical viewer for
       PostGIS data
              I would like to hear from you guys about the viewer you
       use to
              "see"
              PostGIS geometries. Which one is the best and why? How
       do they
              support
              views, editing, creation, etc...
              I can list a couple of them:
              QGIS
              uDIG
              Any others?
              Pierre
              postgis-users mailing list
                    http://postgis.refractions.net/mailman/listinfo/postgis-users
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20080411/b1a5fbc4/attachment.html>
