[postgis-users] Upload Table Warning Message
Obe, Regina
robe.dnd at cityofboston.gov
Fri Apr 11 07:03:27 PDT 2008
How did you generate the sql file. Was it dump of a table from 8.0?
Can you post a snippet of the sql file?
Thanks,
Regina
From: postgis-users-bounces at postgis.refractions.net
[mailto:postgis-users-bounces at postgis.refractions.net] On Behalf Of
Jessica Fendos
Sent: Friday, April 11, 2008 9:55 AM
To: postgis-users at postgis.refractions.net
Subject: [postgis-users] Upload Table Warning Message
Hi list:
I uploaded a table using psql command to both Postgres 8.0 and 8.2. The
upload to 8.2 (with a newer version of PostGIS), I got a warning
message:
INSERT 01
psql:XXXX.sql :01: WARNING: OGC WKT expected, EWKT provided - use
GeomFromEWKT <> for this
What does this mean and how can I avoid this? Thank you for your advice.
Jessica
The substance of this message, including any attachments, may be
confidential, legally privileged and/or exempt from disclosure
pursuant to Massachusetts law. It is intended
solely for the addressee. If you received this in error, please
contact the sender and delete the material from any computer.
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20080411/f6ccd247/attachment.html>
