[postgis-users] Upload Table Warning Message
Jessica Fendos
Jessica.Fendos at state.mn.us
Fri Apr 11 07:46:14 PDT 2008
I did the following:
shp2pgsql (path_to_shapefile).shp tabename > namedsql.sql
psql -h XXX -U XXX -d XXX -f namedsql.sql
J
>>> robe.dnd at cityofboston.gov 4/11/2008 9:03 AM >>>
How did you generate the sql file. Was it dump of a table from
8.0? Can you post a snippet of the sql file?
Thanks,
Regina
From: postgis-users-bounces at postgis.refractions.net
[mailto:postgis-users-bounces at postgis.refractions.net] On Behalf
Of Jessica Fendos
Sent: Friday, April 11, 2008 9:55 AM
To: postgis-users at postgis.refractions.net
Subject: [postgis-users] Upload Table Warning Message
Hi list:
I uploaded a table using psql command to both Postgres 8.0 and 8.2.
The upload to 8.2 (with a newer version of PostGIS), I got a warning
message:
INSERT 01
psql:XXXX.sql :01: WARNING: OGC WKT expected, EWKT provided - use
GeomFromEWKT <> for this
What does this mean and how can I avoid this? Thank you for your
advice.
Jessica
The substance of this message, including any attachments, may be
confidential, legally privileged and/or exempt from disclosure
pursuant to Massachusetts law. It is intended solely for the
addressee. If you received this in error, please contact the sender
and delete the material from any computer.
Help make the earth a greener place. If at all possible resist
printing this email and join us in saving paper.
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20080411/d3583e35/attachment.html>
