[postgis-users] 1.3.3 Pre-Release Notice
Paul Ramsey
pramsey at cleverelephant.ca
Sat Apr 12 11:20:31 PDT 2008
OK, I'm going to roll out 1.3.3. Solaris will have to be tested post
facto... I will set up a Solaris VM here so it's easier to do,
unfortunately it will be testing Solaris-on-x86, not solaris on
sparc64 or something interesting like that.
P
On Sat, Apr 12, 2008 at 4:11 AM, Mark Cave-Ayland
<mark.cave-ayland at siriusit.co.uk> wrote:
> On Thu, 2008-04-10 at 15:21 -0700, Paul Ramsey wrote:
> > I (OS/X 10.5, geos trunk) got no failures in regress_ogc under your
> > patch. We'll see what it was tomorrow I guess.
> Okay, it's all sorted now - it was a mismatch between LF and CR/LF files
> from SVN. The file in question (regress_ogc_expected) had an explicit
> svn:eol-style property set to native; I've removed this but on a fresh
> checkout I still get CR/LF endings on the *_expected files which causes
> diff on MingW to fail. Hmmmm.
> I suspect that the regression tests will need rewriting in the near future
> anyway, but as long as the release checkout comes from a UNIX-type SVN
> client, there won't be any problems. I think we're about good to go at
> this end - any takers for checking Solaris?
> ATB,
> Mark.
> Mark Cave-Ayland
> Sirius Corporation - The Open Source Experts
> http://www.siriusit.co.uk
> T: +44 870 608 0063
> postgis-users mailing list
