[postgis-users] Multipolygons to Polygon
Kevin Neufeld
kneufeld at refractions.net
Wed Apr 16 12:28:24 PDT 2008
Use ST_GeometryN(geometry, int) if you're sure you only have one
geometry in them.
http://postgis.refractions.net/docs/ch06.html#id2964448
You can test this by:
SELECT ST_NumGeometries(the_geom), count(*)
FROM my_tbl
GROUP BY ST_NumGeometries;
If you don't have any check constraints on your table:
UPDATE my_tbl
SET the_geom = ST_GeometryN(the_geom, 1);
-- Kevin
George Silva wrote:
> Hello everyone,
> I have a converted dataset that has only polygons, but they were
> imported from ArcGIS as Multipolygons. I need them to become simple
> polygons. (I dont have any real multi-polygons in the table - they
> were just imported that way.
> How can i convert this dataset to regular tyep polygons *question
> mark* (no question marks on this keyboard :( )
> Thx for the help!
> postgis-users mailing list
