[postgis-users] Three point ARC to MULTILINESTRING
Paul Ramsey
pramsey at cleverelephant.ca
Fri Apr 18 08:33:15 PDT 2008
Use the CIRCULARSTRING type, and the ST_CurveToLine(geometry) function
to convert it to a linestring.
CREATE TABLE test ( GEOM geometry );
INSERT INTO test VALUES ('CIRCULARSTRING(0 0, 1 1, 2 0)');
SELECT ST_AsText(ST_CurveToLine(geom)) FROM test;
P
On Fri, Apr 18, 2008 at 7:53 AM, JohanNL <johan12365 at hotmail.com> wrote:
> Hi All,
> I have a question. I need to store an Arc into a postgis database. As far as
> I know, Postgis doens't support arcs. Is there another way to convert a
> Three Point Arc to a MultiLineString?
> Best regards,
> Johan.
> View this message in context: http://www.nabble.com/Three-point-ARC-to-MULTILINESTRING-tp16763471p16763471.html
> Sent from the PostGIS - User mailing list archive at Nabble.com.
> postgis-users mailing list
