[postgis-users] error with buffer()
Stefan Zweig
stefanzweig1881 at web.de
Tue Apr 22 02:52:47 PDT 2008
hi list,
there seems to be an error within the buffer(geometry, precision) function.
i just tried to the following statement:
UPDATE _g2870 SET the_geom_3_b = buffer(the_geom_3, 0) WHERE isValid(the_geom_3) = false;
and it resulted into a broken connection to the postmaster. postgis seems to have problems with the buffer function and invalid geometries. the server.log says the following:
bufferOriginalPrecision failed (TopologyException: unable to assign hole to a shell), trying with reduced precision
recomputing with precision scale factor = 1e+12
Scaler: offsetX,Y: 0,0 scaleFactor: 1e+12
ReScaler: offsetX,Y: 0,0 scaleFactor: 1e+12
recomputing with precision scale factor = 1e+11
Scaler: offsetX,Y: 0,0 scaleFactor: 1e+11
ReScaler: offsetX,Y: 0,0 scaleFactor: 1e+11
recomputing with precision scale factor = 1e+10
Scaler: offsetX,Y: 0,0 scaleFactor: 1e+10
ReScaler: offsetX,Y: 0,0 scaleFactor: 1e+10
recomputing with precision scale factor = 1e+09
Scaler: offsetX,Y: 0,0 scaleFactor: 1e+09
ReScaler: offsetX,Y: 0,0 scaleFactor: 1e+09
recomputing with precision scale factor = 1e+08
Scaler: offsetX,Y: 0,0 scaleFactor: 1e+08
ReScaler: offsetX,Y: 0,0 scaleFactor: 1e+08
recomputing with precision scale factor = 1e+07
Scaler: offsetX,Y: 0,0 scaleFactor: 1e+07
ReScaler: offsetX,Y: 0,0 scaleFactor: 1e+07
recomputing with precision scale factor = 1e+06
Scaler: offsetX,Y: 0,0 scaleFactor: 1e+06
ReScaler: offsetX,Y: 0,0 scaleFactor: 1e+06
recomputing with precision scale factor = 100000
Scaler: offsetX,Y: 0,0 scaleFactor: 100000
ReScaler: offsetX,Y: 0,0 scaleFactor: 100000
pdata 10.100.6.140(1782) UPDATE: ../../source/headers/geos/noding/SegmentString.h:175: void geos::noding::SegmentString::testInvariant() const: Zusicherung »pts->size() > 1« nicht erfÌllt.
LOG: server process (PID 7510) was terminated by signal 6
LOG: terminating any other active server processes
WARNING: terminating connection because of crash of another server process
DETAIL: The postmaster has commanded this server process to roll back the current transaction and exit, because another server process exited abnormally and possibly corrupted shared memory.
HINT: In a moment you should be able to reconnect to the database and repeat your command.
LOG: all server processes terminated; reinitializing
LOG: database system was interrupted at 2008-04-22 11:18:52 CEST
LOG: checkpoint record is at 0/9A4F7BC8
LOG: redo record is at 0/9A4F7BC8; undo record is at 0/0; shutdown TRUE
LOG: next transaction ID: 0/51508; next OID: 322761
LOG: next MultiXactId: 1; next MultiXactOffset: 0
LOG: database system was not properly shut down; automatic recovery in progress
LOG: redo starts at 0/9A4F7C18
LOG: unexpected pageaddr 0/9161E000 in log file 0, segment 154, offset 6414336
LOG: redo done at 0/9A61D790
LOG: database system is ready
my postgis_version is:
select postgis_full_version()
"POSTGIS="1.3.3" GEOS="3.0.0-CAPI-1.4.1" PROJ="Rel. 4.6.0, 21 Dec 2007" USE_STATS"
any ideas?
regards,
stefan
_______________________________________________________________________
Jetzt neu! Schützen Sie Ihren PC mit McAfee und WEB.DE. 30 Tage
kostenlos testen. http://www.pc-sicherheit.web.de/startseite/?mc=022220
