[postgis-users] error with buffer()
Paul Ramsey
pramsey at cleverelephant.ca
Tue Apr 22 07:57:06 PDT 2008
Send in your geometry! Some geometry/parameter combinations break
ST_Buffer() and we like to add those to our zoo of unusual and
interesting cases for future improvement.
P
In the meantime, try slightly simplifying your geometry first, or
doing your buffer in 2 or more steps of smaller tolerances, or
sacrificing a goat before starting the function call... :)
On Tue, Apr 22, 2008 at 2:52 AM, Stefan Zweig <stefanzweig1881 at web.de> wrote:
> hi list,
> there seems to be an error within the buffer(geometry, precision) function.
> i just tried to the following statement:
> UPDATE _g2870 SET the_geom_3_b = buffer(the_geom_3, 0) WHERE isValid(the_geom_3) = false;
> and it resulted into a broken connection to the postmaster. postgis seems to have problems with the buffer function and invalid geometries. the server.log says the following:
> bufferOriginalPrecision failed (TopologyException: unable to assign hole to a shell), trying with reduced precision
> recomputing with precision scale factor = 1e+12
> Scaler: offsetX,Y: 0,0 scaleFactor: 1e+12
> ReScaler: offsetX,Y: 0,0 scaleFactor: 1e+12
> recomputing with precision scale factor = 1e+11
> Scaler: offsetX,Y: 0,0 scaleFactor: 1e+11
> ReScaler: offsetX,Y: 0,0 scaleFactor: 1e+11
> recomputing with precision scale factor = 1e+10
> Scaler: offsetX,Y: 0,0 scaleFactor: 1e+10
> ReScaler: offsetX,Y: 0,0 scaleFactor: 1e+10
> recomputing with precision scale factor = 1e+09
> Scaler: offsetX,Y: 0,0 scaleFactor: 1e+09
> ReScaler: offsetX,Y: 0,0 scaleFactor: 1e+09
> recomputing with precision scale factor = 1e+08
> Scaler: offsetX,Y: 0,0 scaleFactor: 1e+08
> ReScaler: offsetX,Y: 0,0 scaleFactor: 1e+08
> recomputing with precision scale factor = 1e+07
> Scaler: offsetX,Y: 0,0 scaleFactor: 1e+07
> ReScaler: offsetX,Y: 0,0 scaleFactor: 1e+07
> recomputing with precision scale factor = 1e+06
> Scaler: offsetX,Y: 0,0 scaleFactor: 1e+06
> ReScaler: offsetX,Y: 0,0 scaleFactor: 1e+06
> recomputing with precision scale factor = 100000
> Scaler: offsetX,Y: 0,0 scaleFactor: 100000
> ReScaler: offsetX,Y: 0,0 scaleFactor: 100000
> pdata 10.100.6.140(1782) UPDATE: ../../source/headers/geos/noding/SegmentString.h:175: void geos::noding::SegmentString::testInvariant() const: Zusicherung »pts->size() > 1« nicht erfÌllt.
> LOG: server process (PID 7510) was terminated by signal 6
> LOG: terminating any other active server processes
> WARNING: terminating connection because of crash of another server process
> DETAIL: The postmaster has commanded this server process to roll back the current transaction and exit, because another server process exited abnormally and possibly corrupted shared memory.
> HINT: In a moment you should be able to reconnect to the database and repeat your command.
> LOG: all server processes terminated; reinitializing
> LOG: database system was interrupted at 2008-04-22 11:18:52 CEST
> LOG: checkpoint record is at 0/9A4F7BC8
> LOG: redo record is at 0/9A4F7BC8; undo record is at 0/0; shutdown TRUE
> LOG: next transaction ID: 0/51508; next OID: 322761
> LOG: next MultiXactId: 1; next MultiXactOffset: 0
> LOG: database system was not properly shut down; automatic recovery in progress
> LOG: redo starts at 0/9A4F7C18
> LOG: unexpected pageaddr 0/9161E000 in log file 0, segment 154, offset 6414336
> LOG: redo done at 0/9A61D790
> LOG: database system is ready
> my postgis_version is:
> select postgis_full_version()
> "POSTGIS="1.3.3" GEOS="3.0.0-CAPI-1.4.1" PROJ="Rel. 4.6.0, 21 Dec 2007" USE_STATS"
> any ideas?
> regards,
> stefan
> _______________________________________________________________________
> Jetzt neu! Schützen Sie Ihren PC mit McAfee und WEB.DE. 30 Tage
> kostenlos testen. http://www.pc-sicherheit.web.de/startseite/?mc=022220
> postgis-users mailing list
