AW: RE: [postgis-users] Geometrycollection to Multipolygon
Düster Horst
Horst.Duester at bd.so.ch
Wed Apr 23 07:49:16 PDT 2008
Regina
Thank you for your response. Mmmm.. your trick doesn't solve my problem.
Perhaps I should tell you why I do have a geometrycollection. My
startingpoint is a sequence of single polygons. My aim is to merge them
together to one multipolygon. I do this with st_collect. This works fine
with two polygons:
st_collect(polygon1,polygon2) => multipolygon(1,2).
When I Process the third polygon with: st_collect(multipolygon(1,2),
polygon3) => Geometrycollection(multipolygon(1,2),polygon3)
I do get the geomtrycollection and so on.
My main problem is to merge the three polygons into one multipolygon
with 3 geometries.
When I solve this problem I can offer a procedure to clean invalid
geometries.
Regards
Horst
Dr. Horst Düster
GIS-Koordinator, Stv. Amtschef
Kanton Solothurn
Bau- und Justizdepartement
Amt für Geoinformation
SO!GIS Koordination
Rötistrasse 4
CH-4501 Solothurn
Telefon ++41(0)32 627 25 32
Telefax ++41(0)32 627 22 14
mailto:horst.duester at bd.so.ch
http://www.agi.so.ch
-----Ursprüngliche Nachricht-----
Von: Obe, Regina [mailto:robe.dnd at cityofboston.gov]
Gesendet am: Mittwoch, 23. April 2008 14:24
An: PostGIS Users Discussion
Betreff: RE: [postgis-users] Geometrycollection to Multipolygon
This sometimes does the trick for me if they actually can be unioned
ST_Union(GEOMCOLL, ST_GeomFromText('GEOMETRYCOLLECTION(EMPTY)',
yoursridhere) )
(your number 2 doesn't work because that is the aggregate form, not
because ST_Union can't handle geometry collections I think)
Hope that helps,
Regina
_____
From: postgis-users-bounces at postgis.refractions.net
[mailto:postgis-users-bounces at postgis.refractions.net] On Behalf Of
Düster Horst
Sent: Wednesday, April 23, 2008 2:25 AM
To: postgis-users
Subject: [postgis-users] Geometrycollection to Multipolygon
I do have a Geometrycollection which consists of a collection of
Multipolygons and Polygons. My aim is to create one single
Multipolygon from the mentioned Geometry collection.
Until now I tried the following steps without result:
1. ST_BUFFER(GEOMCOLL,0.0) => It works but all inner rings of my
input geometry are lost.
2. ST_UNION(GEOMCOLL) => doesn't work with Geometrycollections
Does anyone has a solution to solve my problem?
Best regards
Horst
Dr. Horst Düster
Kanton Solothurn
SO!GIS Koordination
Rötistrasse 4
CH-4501 Solothurn
_____
The substance of this message, including any attachments, may be
confidential, legally privileged and/or exempt from disclosure
pursuant to Massachusetts law. It is intended solely for the
addressee. If you received this in error, please contact the sender
and delete the material from any computer.
_____
Help make the earth a greener place. If at all possible resist
printing this email and join us in saving paper.
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20080423/2d5b5a6e/attachment.html>
