AW: RE: [postgis-users] Geometrycollection to Multipolygon
Stephen Woodbridge
woodbri at swoodbridge.com
Wed Apr 23 08:59:24 PDT 2008
I think you are getting the collection because you are mixing types.
Try this (I haven't tried it):
st_collect(
st_collect(st_multi(polygon1), st_multi(polygon2)),
st_multi(polygon3))
and see if you get a multipolygon ot a collection as the result.
-Steve W
Düster Horst wrote:
> Regina
> Thank you for your response. Mmmm.. your trick doesn't solve my problem.
> Perhaps I should tell you why I do have a geometrycollection. My
> startingpoint is a sequence of single polygons. My aim is to merge them
> together to one multipolygon. I do this with st_collect. This works fine
> with two polygons:
> st_collect(polygon1,polygon2) => multipolygon(1,2).
> When I Process the third polygon with: st_collect(multipolygon(1,2),
> polygon3) => Geometrycollection(multipolygon(1,2),polygon3)
> I do get the geomtrycollection and so on.
> My main problem is to merge the three polygons into one multipolygon
> with 3 geometries.
> When I solve this problem I can offer a procedure to clean invalid
> geometries.
> Regards
> Horst
> Dr. Horst Düster
> GIS-Koordinator, Stv. Amtschef
> Kanton Solothurn
> Bau- und Justizdepartement
> Amt für Geoinformation
> SO!GIS Koordination
> Rötistrasse 4
> CH-4501 Solothurn
> Telefon ++41(0)32 627 25 32
> Telefax ++41(0)32 627 22 14
> mailto:horst.duester at bd.so.ch
> http://www.agi.so.ch <http://www.agi.so.ch/>
> -----Ursprüngliche Nachricht-----
> *Von:* Obe, Regina [mailto:robe.dnd at cityofboston.gov]
> *Gesendet am:* Mittwoch, 23. April 2008 14:24
> *An:* PostGIS Users Discussion
> *Betreff:* RE: [postgis-users] Geometrycollection to Multipolygon
> This sometimes does the trick for me if they actually can be unioned
> ST_Union(GEOMCOLL, ST_GeomFromText('GEOMETRYCOLLECTION(EMPTY)',
> yoursridhere) )
> (your number 2 doesn't work because that is the aggregate form, not
> because ST_Union can't handle geometry collections I think)
> Hope that helps,
> Regina
> *From:* postgis-users-bounces at postgis.refractions.net
> [mailto:postgis-users-bounces at postgis.refractions.net] *On Behalf Of
> *Düster Horst
> *Sent:* Wednesday, April 23, 2008 2:25 AM
> *To:* postgis-users
> *Subject:* [postgis-users] Geometrycollection to Multipolygon
> I do have a Geometrycollection which consists of a collection of
> Multipolygons and Polygons. My aim is to create one single
> Multipolygon from the mentioned Geometry collection.
> Until now I tried the following steps without result:
> 1. ST_BUFFER(GEOMCOLL,0.0) => It works but all inner rings of my
> input geometry are lost.
> 2. ST_UNION(GEOMCOLL) => doesn't work with Geometrycollections
> Does anyone has a solution to solve my problem?
> Best regards
> Horst
> Dr. Horst Düster
> Kanton Solothurn
> SO!GIS Koordination
> Rötistrasse 4
> CH-4501 Solothurn
> *The substance of this message, including any attachments, may be
> confidential, legally privileged and/or exempt from disclosure
> pursuant to Massachusetts law. It is intended solely for the
> addressee. If you received this in error, please contact the sender
> and delete the material from any computer. *
> * Help make the earth a greener place. If at all possible resist
> printing this email and join us in saving paper. *
> postgis-users mailing list
