[postgis-users] Ubuntu 8.04 and PostGIS / GEOS versions again
Chris Hermansen
chris.hermansen at timberline.ca
Fri Apr 25 13:15:34 PDT 2008
Hi Colin;
We're OK with making our own packages; my original impetus was around
the idea that "if we're wanting to do this, probably others are too", so
why not share the results in the end.
Colin Wetherbee wrote:
> Chris Hermansen wrote:
>> Colin Weatherbee has kindly corrected my total lack of e-mail polish
>> and further advised that Ubuntu 8.04 PostGIS and GEOS offerings are
>> right up to date.
> I hope that works out. :)
>> That being the case, I will postpone asking the list about
>> alternatives to building new PostGIS related components from source
>> when one's server distros are getting a bit long in tooth until I
>> really need to know.
> Your previous email, I believe, suggested you were more interested in
> using packages than building from source.
> In case you're interested in something slightly different...
> Ubuntu provides package-creation tools, if you need to bundle your own
> packages from a source build.
> I use Debian, on which Ubuntu is based, and if I were going to build
> my own packages, I'd start by reading up on the dpkg-dev package. It
> might be called something slightly different in Ubuntu.
> `apt-cache show dpkg-dev` says:
> Recommends: build-essential, gcc | c-compiler
> Description: package building tools for Debian
> This package contains the tools (including dpkg-source) required to
> unpack, build and upload Debian source packages.
> Most Debian source packages will require additional tools to build -
> for example, most packages need the `make' and the C compiler `gcc'.
> Homepage: http://wiki.debian.org/Teams/Dpkg
> Colin
> postgis-users mailing list
Regards,
Chris Hermansen mailto:chris.hermansen at timberline.ca
tel+1.604.714.2878 · fax+1.604.733.0631 · mob+1.778.232.0644
Timberline Natural Resource Group · http://www.timberline.ca
401 · 958 West 8th Avenue · Vancouver BC · Canada · V5Z 1E5
