[postgis-users] Line To Path
Paragon Corporation lr at pcorp.us
Wed Apr 30 15:20:15 PDT 2008
Bob,
If I understand you correctly, I think you want to use one of the following
SELECT somefield, ST_Union(the_geom)
FROM sometable
GROUP BY somefield
So lets say you want to collapse 3 rows into 1 then you just need to group
by some common field.
E.g. if somefield = 1 for your 3 records, then those would get rolled into
the same record.
The above will give you a LINESTRING or MULTILINESTRING.  If you have all
LINESTRINGS, then may be more efficient to do this.  The below will first
collapse all with common somefield into a MULTILINESTRING and then the
LineMerge will do the best it can to stitch back into a single line string.
This is not possible with completely disjoint linestrings.
SELECT somefield, ST_LineMerge(ST_Collect(the_geom))
FROM sometable
GROUP BY somefield
If you are using the older version of Postgis, you can just take out the ST_
in the examples I have above.
Hope that helps,
Regina
-----Original Message-----
From: postgis-users-bounces at postgis.refractions.net
[mailto:postgis-users-bounces at postgis.refractions.net] On Behalf Of Bob
Pawley
Sent: Wednesday, April 30, 2008 12:40 PM
To: PostGIS Users Discussion
Subject: [postgis-users] Line To Path
Is there a method of converting three lines that require three rows into a
path that occupies a single row??
Bob Pawley
postgis-users mailing list
postgis-users at postgis.refractions.net
http://postgis.refractions.net/mailman/listinfo/postgis-users
