[postgis-users] postgis on Debian 4.0
Mark Cave-Ayland
mark.cave-ayland at siriusit.co.uk
Fri Aug 1 03:41:19 PDT 2008
Adrian wrote:
> I'm trying to create a postgis database on a brand new install of Debian
> 4.0r2 (which I understand is the stable, rock solid no problems
> version), using the following steps:
> aptitude install postgresql-8.1-postgis
> su - postgres
> createuser <username>
> createdb -E UTF8 -O <username> <dbname>
> createlang plpgsql <dbname>
> Everything looks OK until I do
> psql -d gis -f /usr/share/postgresql-8.1-postgis/lwpostgis.sql
> and then I get lots of error messages that start with:
> psql:/usr/share/postgresql-8.1-postgis/lwpostgis.sql:39: NOTICE: type
> "histogram2d" is not yet defined
> DETAIL: Creating a shell type definition.
> psql:/usr/share/postgresql-8.1-postgis/lwpostgis.sql:39: ERROR: could
> not load library "/usr/lib/postgresql/8.1/lib/liblwgeom.so.1.1":
> /usr/lib/postgresql/8.1/lib/liblwgeom.so.1.1: undefined symbol:
> vacuum_delay_point
> psql:/usr/share/postgresql-8.1-postgis/lwpostgis.sql:44: ERROR: current
> transaction is aborted, commands ignored until end of transaction block
> Any suggestions on how to fix it? I would have though many people have
> been here before me, but I can't find them with Google. It looks to me
> like the 8.1 version of the lwpostgis.sql script doesn't match the
> shared library in the 8.1 release.
Eh? This looks like a broken package/installation - vacuum_delay_point
was added in PostgreSQL 8.0 and so something else is wrong here. Are you
sure you don't have multiple versions of PostGIS / lwpostgis.sql installed?
BTW PostgreSQL 8.1 and PostGIS 1.1 are both extremely old - you should
really consider building the latest PostGIS 1.3.x release to avoid
several nasty PostGIS bugs, and preferably a newer version of PostgreSQL
at the same time.
ATB,
Mark.
Mark Cave-Ayland
Sirius Corporation - The Open Source Experts
http://www.siriusit.co.uk
T: +44 870 608 0063
