[postgis-users] Merge all polygons from a dataset
danny whatevar89 at gmail.com
Fri Aug 1 08:31:38 PDT 2008
Thanks Robert.
I actually exported from ogr2ogr and it created a shape that worked fine in
ArcView.
Best
On Fri, Aug 1, 2008 at 5:19 PM, Burgholzer,Robert <
rwburgholzer at deq.virginia.gov> wrote:
>  Could ArcView perhaps want some columns other than just the shape?
> Perhaps you could put a numeric ID or something else in there.
> Just a thought,
> Robert W. Burgholzer
> Surface Water Modeler
> Office of Water Supply and Planning
> Virginia Department of Environmental Quality
> 804-698-4405
> Open Source Modeling Tools:
> http://sourceforge.net/projects/npsource/
> -----Original Message-----
> *From:* postgis-users-bounces at postgis.refractions.net [mailto:
> postgis-users-bounces at postgis.refractions.net] *On Behalf Of *danny
> *Sent:* Friday, August 01, 2008 9:30 AM
> *To:* PostGIS Users Discussion
> *Subject:* Re: [postgis-users] Merge all polygons from a dataset
> Many thanks, Regina! Indeed ST_Union generated the polygon, invisible in
> PgAdmin!!
> It creates a nice layer when I open it in uDig.
> However when I export it with pgsql2shp, the shape is unreadable by ArcView
> with the errmsg: Number of shapes does not match the number of table
> records.
> Here's how I created the layer:
> create table europe_contour();
> SELECT addgeometrycolumn('db, 'europe_contour', 'the_geom',
> 32767,'MULTIPOLYGON', 2 );
> insert into europe_contour(the_geom) values( (select st_union(the_geom)
> from europe));
> Then I generate the shapefile:
> "c:\Program Files\PostgreSQL\8.3\bin\pgsql2shp.exe" -u postgres -P password
> -f europe_contour db europe_contour
> Any suggestions perhaps on anything I've wrong?
>  On Fri, Aug 1, 2008 at 1:15 PM, Obe, Regina <robe.dnd at cityofboston.gov>
> wrote:
> Erik,
> How were you using ST_Union and what exactly do you mean by no result.  no
> result as it looks blank?  If you are using something like PgAdmin III - it
> will look blank because it exceeds the buffer supported by PgAdmin III.
> SELECT the_geom is null
> FROM (somequery or table) as foo
> LIMIT 1
> will tell you if its actually returning no geometry
> Hope that helps,
> Regina
> *Sent:* Friday, August 01, 2008 6:12 AM
> *To:* postgis-users at postgis.refractions.net
> *Subject:* [postgis-users] Merge all polygons from a dataset
> Hello everybody,
> I've converted a shapefile of Europe to PostGIS. I would like to merge all
> the countries together so that I only have one polygon left, the whole
> contour of Europe. I have tried ST_Union that gives me no result. I've tried
> several other functions to no avail. Does anybody know how I should proceed?
> Many thanks,
> Erik
> *The substance of this message, including any attachments, may be
> confidential, legally privileged and/or exempt from disclosure pursuant to
> Massachusetts law. It is intended solely for the addressee. If you received
> this in error, please contact the sender and delete the material from any
> computer. *
> *Help make the earth a greener place. If at all possible resist printing
> this email and join us in saving paper. *
> postgis-users mailing list
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20080801/99a55819/attachment.html>
