[postgis-users] JSON
Sophie GRAS
sophie.gras at espaces-naturels.fr
Mon Aug 4 02:00:50 PDT 2008
Thanks a lot Olivier, now everything is fine !
I am right now beginning to test geoadminsuite, mapfish and mapserver and trying to determine wich solution is the best for my work...
Could you answer to some question in case of i need some advice ?
Thanks anyway
Sophie
----- Mail Original -----
De: "Courtin Olivier" <olivier.courtin at camptocamp.com>
À: "PostGIS Users Discussion" <postgis-users at postgis.refractions.net>
Envoyé: Lundi 4 Août 2008 10:06:32 GMT +01:00 Amsterdam / Berlin / Berne / Rome / Stockholm / Vienne
Objet: Re: [postgis-users] JSON
On Aug 4, 2008, at 8:38 AM, Sophie GRAS wrote:
> Hi everybody,
> thnaks for your answers !
> I have downloaded a svn client, but after that how can i upgrade my
> postgis (i am so new at linux !!) ?
In a perfect world you just have to follow steps 1 and 2.
Zero step is describted as an extra... ;)
0) Check to have:
- svn client: which svn
- gcc and libc: which gcc
- autoconf, make which make && which autoconf
- postgresql with pg_config binary which pg_config
- lib iconv sudo ldconfig -v | grep iconv
- flex and bison which flex && which bison
- /usr/local/lib in LD_LIBRAY_PATH sudo ldconfig -v | grep /usr/local/
lib
(if not: su -c "echo '/usr/local/lib' >> /etc/ld.so.conf &&
ldconfig" )
not required but usefull:
- geos with geos-config binary which geos-config
- lib proj4 sudo ldconfig -v | grep proj
0') If you need to install Proj4 from source:
wget http://download.osgeo.org/proj/proj-4.6.0.tar.gz
tar xvzf proj4-4.6.0.tar.gz
cd proj4-4.6.0
./configure && make
sudo make install
sudo ldconfig
cd ..
0'') If you need to install GEOS from source:
wget http://geos.refractions.net/downloads/geos-3.0.0.tar.bz2
tar xvjf geos-3.0.0.tar.bz2
cd geos-3.0.0
./configure && make
sudo make install
sudo ldconfig
cd ..
1) To retrieve source code and compile:
svn checkout http://svn.refractions.net/postgis/branches/1.3 postgis-1.3
cd postgis-1.3/
sh autogen.sh
./configure
make
sudo make install
sudo ldconfig
2) And now to create a new spatial database:
createdb -U postgres foo
createlang -U postgres plpgsql foo
psql -U postgres foo < lwpostgis.sql
psql -U postgres foo < spatial_ref_sys.sql
And to check that everything is A OK:
psql -U postgres -c "SELECT postgis_full_version()" foo
HTH,
Olivier
postgis-users mailing list
http://postgis.refractions.net/mailman/listinfo/postgis-users
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20080804/ea2b7070/attachment.html>
